Uncool, tranny drain plug stripped
Old Nov 29, 2011 | 10:19 PM
Sharkey's Avatar
i have to deal with stripped plugs on transmissions all the time, and had to deal with both a stripped drain and fill plug on my cobalt after the previous owner stripped them. what i like to do with allen heads that are stripped is first try hammering a socket just larger, sometimes you get lucky finding something close going from metric to standard. if that doesnt work, try a torx socket. failing that, i break out my big chisel and 20oz hammer. what i do is on one side of the plug ill drive the chisel straight in till it makes an indent, then drive it at roughly a 45 degree angle in the direction to loosen it. the sharp blow will drive the chisel in and should help turn the bolt. i do this all the time and generally have great success.
fyi- if you buy new plugs from gm, only ask for the fill plug, or if you need both, get 2 fill plugs. they are different part numbers, the difference is the drain plug has an added magnet that comes out of the plug easily. the fill plug is $6, the drain plug is $35.
Old Nov 30, 2011 | 11:39 AM
145CIBALT's Avatar
listen not to be rude but i take care of this everyday. On Cobalts. F35. I use a 3/8 extension, a 3/8 drive metric allen socket on the end, an impact driver on the extension and a B F Hammer. Surely I dont need to post apicture?
its not a power tool. its an impact driver.
My fault. I was mistaken about the impact driver. If you've done this on a f23 drain plug than i would appreciate a picture since I don't see how it could be done. I don't pretend to be an expert so I'm not doubting it can be done I just don't see how.
Old Nov 30, 2011 | 11:45 AM
Powell Race Parts's Avatar
I referred to an F35. I will check the F23 I have one of those trans in my eco cavvy wntr btr... let u know
Old Dec 11, 2011 | 12:53 PM
Ronn2005's Avatar
Fill plug & drain plug part number?
Does anyone know what the part number is to the f35 transmission fill plug and drain plug?
Old Jan 17, 2014 | 09:16 AM
exninja's Avatar
Sorry to resurrect the thread, but I'm also interested in the part numbers for the plugs
hacadacalopolis
Oct 28, 2015 06:09 PM
OrangeCoba
Oct 1, 2015 10:00 PM
MrInsanityWolf
Sep 29, 2015 04:54 PM
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
