Using I gear in traffic?
Old Nov 7, 2007 | 08:35 AM
GULLABLE0NE's Avatar
i encounter a lot of traffic when i get out of work and the stop and go is killing my brakes. The last few days i've been driving in the I gear so i'm not slamming the brakes every 5 seconds. I know this gear should usually be used for inclines but is this gear also a good idea to use in traffic?
Old Nov 7, 2007 | 08:37 AM
cougar2588's Avatar
hmm good question... im subscribed cuz i wanna hear an answer.
Old Nov 7, 2007 | 01:48 PM
me too
Old Nov 7, 2007 | 01:49 PM
D4u2s0t's Avatar
you'll be fine. "I" is a normal driving gear. just don't go pretending you have a manual and start shifting back and forth.
Old Nov 7, 2007 | 02:10 PM
HunterKiller89's Avatar
yes and no....using the gears on an automatic makes the tq converter spin when your not on the gas, which heats the tranny fluid as well...however, since your not moving much in traffic, its not being cooled down much when it passes through the radiator. i would avoid it on really hot days when in traffic for a long time....otherwise, its no big deal and is totally safe
Old Nov 7, 2007 | 04:03 PM
thanx
Old Nov 7, 2007 | 04:12 PM
Archie's Avatar
You should be fine.
If you aren't 100% confident, you could always do what I do.
Get an aeroforce interceptor gauge, and watch your tranny temperatures while in traffic. 150-175 seems to be about normal for my car. When using "I" in traffic, it usually stays at about 170*, but will occasionally reach about 180 when coming to a stop, and sitting there for a bit. As soon as I start moving again, it drops right back to 170ish.
I would like to test it on the the road into Canyon Lake, lots of low speed twisties.
Old Nov 7, 2007 | 10:54 PM
Sharkey's Avatar
you will not do any damage driving your car like that. just remember, if it can damage the tranny, gm wouldnt have put it there as they would have to fix it under warrenty
06MetallicBalt
Jul 20, 2025 08:47 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
biniecki
Oct 25, 2015 02:23 PM
DocSvensk
Sep 27, 2015 02:24 PM
