what clutch?
Old Nov 10, 2012 | 10:09 PM
chevy350's Avatar
what clutch?
It is almost time to replace my clutch. I was wondering what aftermarket clutch you guys would recommend that will last longer than oem? I have gm1 and no other significant mods.
Thanks
Old Nov 10, 2012 | 10:11 PM
kdub1492's Avatar
Any future mods? If thats all you plan on doing then just go like Spec s2, ky stage 3 (although not needed with ur mods), zzp stage 2..any will work
Old Nov 10, 2012 | 10:38 PM
TurboTechRacing's Avatar
Best value will be the ky stage 3.
Old Nov 11, 2012 | 12:13 AM
AyrtonSenna's Avatar
I would listen to TTR guys if I was you. Expecially after releasing that manifold, they get from me all the credit possible.
Old Nov 12, 2012 | 10:39 AM
chevy350's Avatar
Is this the one?
KY Clutch - Chevrolet Cobalt/HHR 2.0L F35 Trans Stage 3
Is there one that is not the "puck" syle? I would prefer one that was not. No future mods except poss. CAI.
Thank you!!!
Old Nov 12, 2012 | 11:59 AM
Originally Posted by chevy350
Is this the one?
Thank you!!!
To hold the power you must have a puck style. It is all about clamping force and PSI on the disc surface to hold.
Even ZZP's and SPEC "+" which are claimed to be "full face disc" is a puck on the stage 3 & 4. It is the steel backer that is a full circle on theirs, but if you look closely there is still pads/pucks on them; which is no different than a puck. Nothing wrong with how they do it, but it all comes down to you have to do it this way to hold power.
Old Nov 12, 2012 | 12:04 PM
dakotaspeir's Avatar
#cobalthoes
Ky stage 3 clutch,Throw out bearing, Transmission fluid, Clutch Pipe, Flywheel bolts, Flywheel (either new or get yours resurfaced) Everything you will need.
Old Nov 12, 2012 | 12:30 PM
duffman11's Avatar
Aaron is a good guy. I've heard 95% good things from the KY clutches. The 5% is just that bad part. Thats always a risk when you buy anything. You'll be happy with the KY. I would also recomend new flywheel bolts and flywheel. Might as well make sure everything is good to go.
Old Nov 15, 2012 | 11:08 PM
chevy350's Avatar
Thank you guys! Am looking into it as we speak It looks like stage 3 is over kill for me rated at"475 ft lbs torque capacity" where as stage 2 rated at " 365 ft lbs torque capacity" would sound to be a better fit. I have heard of "chattering" with some of the puck clutches. Any truth to these claims?may have a cpl questions later.
Old Nov 16, 2012 | 01:32 AM
On the SS/TC get the stage 3, it is not that much more... Issue is the LNF has so much low end torque, you need a stage 3 to hold it. Plus you wont be stressing the stage 3 at all compared to the stage 2.
Most all LNF members get the stage 3
Most all LSJ members get the stage 2
Hope this helps.
Old Nov 16, 2012 | 04:04 AM
chevy350's Avatar
You did not mention anything about the chattering. I have heard about chatter with this design. Thoughts?
Old Nov 16, 2012 | 07:07 AM
Mine does not chatter. I use the stage 3 also. It is all in how you engage/disengage the clutch.
Old Nov 16, 2012 | 08:36 AM
Nfamous60's Avatar
I have a Spec stage 3+ doubt you want to spend wut i spent go with ttr they kno their stuff!!! from the reviews you wont be srry.
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
SSLOW06
Oct 1, 2015 07:21 PM
Tupp
Sep 30, 2015 08:18 PM
