what is it? Please help.
Old Dec 21, 2013 | 10:54 PM
BlackielawlessSS's Avatar
Unhappy what is it? Please help.
Lsj 05 ss. 1st to second can be very sloppy. Stock shifter. At times I need to double clutch to make it change gears smoothly. Is it the shifter or the trans. Even slowing down with the clutch in at around 15 mph first is impossible to find. I have no grinding. Just trans slop.please help me.
Old Dec 22, 2013 | 12:51 AM
06cobalt racer's Avatar
check your cables first. they might have popped out
Old Dec 22, 2013 | 12:52 AM
chris88z24's Avatar
Change the trans mounts
Old Dec 22, 2013 | 01:19 AM
Sox-Fan's Avatar
Got Brakes?
stop the car on level ground. put the car in first. push the clutch down. run the motor up to near the red line. if the car moves your clutch is not fully disengaging, in which case you're looking at throwout bearing.
Old Dec 22, 2013 | 01:54 AM
mexi_loco's Avatar
Do you still have stock mounts? If not, then it could have something to do with the throw out bearing or clutch rod. If so, then I would change them out.
Old Dec 22, 2013 | 09:42 AM
I believe they are stock mounts. I had been reading about the rods. I guess it's time to figure this out. It's getting worse.
Old Dec 22, 2013 | 11:11 AM
mexi_loco's Avatar
stock mounts are horrible on the lsj. If you're not planning on putting down big power, you should just get the upgraded mounts (basically they're lnf mounts). Otherwise get some rotated mounts from your favorite vendor or slap some polyurethane inserts in there (if you don't mind turning your car into an oversized vibrator for a couple thousand miles).
Old Dec 22, 2013 | 02:49 PM
Thanks for the help man. I also noticed today when you are slowing down to a stop it will not go into first unless you double ckutch it. The clutch itself feels strong. Is it possible the shifter it's self is messed up? It feels extremely sloppy.
turbochargedss2012
Sep 20, 2023 12:17 PM
Sep 30, 2015 07:22 AM
twilson380
Sep 14, 2015 10:52 AM
CobaltSS 16
Sep 12, 2015 02:43 PM
