Will it Run Rich?
Old Mar 11, 2014 | 05:42 PM
BadAssBowTi's Avatar
Will it Run Rich?
I have a 07 Ls Cobalt and i just got some headers and a cat back exhaust however i dont have a down pipe. should i just get the stock down pipe cut and fitted to the exhaust or can i get a different downpipe without the catalytic converter? will running the car without the second O2 sensor make it run rich?
Old Mar 11, 2014 | 05:47 PM
It will through a code for emissions out of check, that's all your second o2 sensor controls. You can purchase a catless downpipe from a lot of different suppliers, zzp is a good one. Or you can go your route and just hack out the cat, it will most likely add a raspy/ricey sound to your exhaust.
Btw on these cars its a header, we're not a v-6/8 with 2.
Old Mar 11, 2014 | 05:48 PM
umrdyldo's Avatar
The second 02 sensor is only there is judge if you have a cat.
So it will throw codes for no cat, but it will not affect the rich/lean mixture of the car.
Old Mar 11, 2014 | 05:50 PM
Thanks for the advice. but even though its a after market exhaust and header there would still be a ricey sound? also if i got a catless downpipe how would i know it will fit with the other after market header and exhaust i got
Old Mar 11, 2014 | 06:55 PM
07cobaltLScoupe's Avatar
what brand header and cat-back did you pick up? for down pipe your best option is probably a 2.5" ZZP high-flow catted version, not many other brands for a 2.2 and if you go catless it will sound horrible (although some people do like that )
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
tomj77
Oct 4, 2015 11:39 AM
dieGone
Oct 1, 2015 06:27 PM
Extremespeed
Sep 29, 2015 04:34 AM
