zzp f40 swapped cobalts!!!
Hows the car drive, shift, and handle the power? How much power are you putting down? Any issues? If so what was the problem and how did you fix it? Did you install your self or have zzp install the f40? How easy/hard was the install if you did it your self? Thanks!!
Once zzp gets a kit together ill be the 2nd balt do do it my self. Besides dropping the lower cradle. What would you say was the hardest part of the install? How do you like the 6spd? Have you took it to the track yet?
I am one waiting for axle and jack shaft so have not even drove it yet. In all honesty I can drop the cradle like no ones business lol so that's not hard. With no instructions the shifter is actually hard to figure out to put it together lol. There's a weird plastic piece and I still haven't got it. Waiting on Matt to email me back but it's the weekend.
The swap actually uses the f35 mounts, so don't get rid of them. The shifter cables are easy to do with the motor out. Your best bet is to drop the whole cradle pull the engine off and then change the trans out. You can get ZZP to modify the twm but I chose to go with the new buick shifter. I got a couple pics of how I did it in the garage, I too used a jack and stands but my way is easy.
put the car in the air, take off the front clip pull the crash support, get you three 2x4's and screw them together to use as a support to jack the car up and down. Remove all the wiring harness, get a furniture dolly and lower the car down until it set on the dolly, don't put all the weight on there. Remove all the cradle bolts and then jack the car up and the cradle will stay on the dolly to be rolled out the front. Has to get turned sideways to come out tho. Don't forget the steering colum bolt either.
It can be done that way
Last edited by cmiller8006; Jun 23, 2013 at 05:34 PM. Reason: Automerged Doublepost
