zzp f40 swapped cobalts!!!
ok so i think my f35 is going to **** so im at a crossroads between trying to rebuild one (hopefully with lsd) with new components stronger bolts, cryo etc, or going with an f40 swap.
all in all, what is really needed to do this minus the 07+ 9-3 trans, a shifter, perhaps speed sensors and dont you need different axles?
id LIKE to keep this under 3k but i know im probably crazy. and obvs a rebuild f35 would be the cheaper route.
Your going to be at least 3500.00 I think. You will need the zzp kit. Don't try to do it without. You need the intermediate shaft, new axle, clutch disk, mounts and the stuff you mentioned.
thanks. i kinda figured haha. probly best most complete way to do it. id kinda wanna piece it together. #cheap-ass status# maybe get the trans and rebuild, get the clutch and flywheel(s), then order the kit?
jcalvin1126
Sep 11, 2015 10:24 AM
