Dyno Results Dyno pictures, videos and dyno results.
2.2 ecotec tvs 1320 harrop LS4
Old Sep 1, 2015 | 03:43 PM
Ukchilll's Avatar
Old Sep 1, 2015 | 03:54 PM
JapEatr's Avatar
South Central *********
you need fuel up top in a bad way
Old Sep 1, 2015 | 03:58 PM
Ukchilll's Avatar
was hoping someone could pin point my issue up top
ive tried playing around with a few things to it smooth off,
do you know what afrs i should be aiming for
this is what i have
Old Sep 1, 2015 | 03:59 PM
JapEatr's Avatar
you are likely out of pump
JapEatr's Avatar
you on ethanol?
Old Sep 1, 2015 | 04:04 PM
Ukchilll's Avatar
ive tried adding fuel in the dip but it gets worse ive also played with the ignition but still not been able to get rid of the dip
my first thoughts were it was aroung the limits of the intake manifold ??
any thoughts
Old Sep 1, 2015 | 04:05 PM
Ukchilll's Avatar
no just on pump fuel 99 ron here in uk
Old Sep 1, 2015 | 04:08 PM
Ukchilll's Avatar
the car is not running lean on these runs its holding at around 11.8
and no knock retard
Old Sep 1, 2015 | 04:21 PM
JapEatr's Avatar
more than likely camshaft/head
Old Sep 1, 2015 | 04:25 PM
which 2.2 do you have? the L61 or LAP?
Old Sep 1, 2015 | 04:30 PM
JapEatr's Avatar
so your AFR is logged with Wideband?
Old Sep 1, 2015 | 04:37 PM
Ukchilll's Avatar
yep
red line here
Old Sep 1, 2015 | 04:42 PM
Ukchilll's Avatar
its a L61
we call it z22se in the uk
it uses a difefrent ecu i think
the engine is actuall originally a saab b207 2.0 with the craank out of the z22se (2.2) with forged pistons rods cams (zzp stage 2) valve springs etc
Old Dec 1, 2015 | 12:23 PM
Ukchilll's Avatar
new shift light
Old Dec 1, 2015 | 12:32 PM
what pulley are you on?
Old Dec 2, 2015 | 02:54 AM
Ukchilll's Avatar
I'm on a 3.1"
Old Jul 4, 2016 | 01:43 PM
Ukchilll's Avatar
Old Jul 4, 2016 | 05:09 PM
Viperoni's Avatar
Can't comment on the issue, but it looks like your scales are a little off on the Y axis...
Nice to see 300ftlb of torque at only 2k rpm though!
SSLOW06
Oct 1, 2015 07:21 PM
Tupp
Sep 30, 2015 08:18 PM
Dylan Johnson
Sep 30, 2015 08:57 AM
goaliemo
Sep 28, 2015 01:37 PM
