Disappointing Dyno Results
My current mods are as follows:
2006 SS/SC
OTTP Stage 1 (2.8" pulley, 60 lb injectors, BKR7e injectors, canned tune)
RAW 3" Intake
Poly Transmission Mounts
Magnaflow muffler with stock exhaust manifold, downpipe, and piping
Video and Dyno chart will be uploaded later on.
Results:
229 whp/ 213 wtq @ 11.23 AFR on a Dyno Jet dyno
Nitrous pull was attempted but nitrous sillenoid wouldn't work, so no results from those pulls.
Discuss!
2006 SS/SC
RAW 3" Intake
Results:
Discuss!
Dyno numbers mean nothing. You need a base line to know if you made horsepower or not. If dyno is setup wrong it will read low and some dynos just read lower period.
My buddy had a 2.8/60's and Injen intake and made 260 whp. No exhaust. No cooling. But like I said, all dynos read different.
that may be true but a ls4 will help him see bigger numbers with that bigger intake. The supercharger inlet is like 10mil biigrer then the stock tb. So you get a bigger tb and your not trying to suck a fucken golf ball thru a water hose any more
Have you seen the dyno results where people lost hp due to the ls4tb?Some gained 10hp just by putting the stock tb back on.
remember, bigger will increase volume but will slow down air speed, hence why midly modded lsj's dont need them, not moving nearly enough air
ima not going 2 waste my breathe then. you guys must not have one bc your would be singing a different tune. at 19 lbs of boost that ls4 is more beneficial then the stock tb. thats all i am saying about the tb issue.
Canned tune FTL
I only put down 209 with my OTTP stg. 1. I will never run a canned tune again! I am building a TVS 340whp build right now. I was removing my original pistons and they were filthy and black with only 20k miles on my car.
