Dyno Results Dyno pictures, videos and dyno results.
Disappointing Dyno Results
Old Dec 16, 2009 | 04:20 PM
06blackg85ss's Avatar
Originally Posted by GreyDog72
that may be true but a ls4 will help him see bigger numbers with that bigger intake. The supercharger inlet is like 10mil biigrer then the stock tb. So you get a bigger tb and your not trying to suck a fucken golf ball thru a water hose any more
It's not needed, I've made over 500whp on the stock tb. LS4 tb is good, but **** for driving in traffic.
Old Dec 16, 2009 | 05:41 PM
WickedSS2005's Avatar
Get STOP mounts from TTR. That'll get you your power
Old Dec 16, 2009 | 07:41 PM
rockSTAR_SS's Avatar
The reason I wasn't making good power is because the MAF was turned off on my car. The car was basically running a VE tune, and it wasn't doing well at all. How do you think that happened Wicked?
Needless to say I had somebody fix all of that for me
Old Dec 16, 2009 | 08:05 PM
Was the tune setup that way? Or possibly the MAF being unplugged/dead are only two ways
Old Dec 16, 2009 | 08:10 PM
MAF wasn't unplugged and is working just fine right now.
If it was set-up that was, it wasn't by my decision. I didn't know anything about it until after like 5 minutes of data logging the tuner was like "You know your MAF is off, right?"
"Uhhhh......."
Old Dec 17, 2009 | 12:50 AM
ralliartist's Avatar
you guys arguing over the LS4 TB are making some very inaccurate statements. It isn't goint to hurt power, maybe drop a few hp for Peak numbers, but who really cares? The power under the curve will be quite a bit better, you'll feel the gain down low.
As for the OP's dyno being so low, it could just be the dyno itself, or it could be a number of things. Restrictive exhaust flow at the header/dp, need more cooling mods, better tune, etc.
Old Dec 17, 2009 | 03:02 AM
Or it could be that he was not using his MAF and was using an untuned VE table somehow as stated by the OP a few posts above yours
Old Dec 17, 2009 | 03:42 AM
that would be the problem right there, but I did say "better tune" lol.
Old Dec 24, 2009 | 11:12 AM
phatnackySS's Avatar
It could be your intercooler pump. come on guy's it disturbs me that no one ever brings up the number 1 problems with these cars. your IC may not be working.
I was on GMsII with header no cat, and aux heat exchanger got a dyno put down 226whp. i had also noticed my trap speed at the track had drop to into the 97-98 range. pump has been fixed ,i haven't re-dynoed but my trap speed is back up to 100-103.
Old Dec 24, 2009 | 02:54 PM
problem was already stated
brickloaf
Show & Shine
56
Jun 18, 2019 12:51 PM
Jan 12, 2016 12:01 AM
maliki778
Oct 1, 2015 07:39 PM
footballplaya3k
Sep 28, 2015 11:14 AM
Sep 27, 2015 08:53 PM
