Dyno Day.
Dyno Day.
Hoping for some decent numbers. Car is on the trailer ready to go.
For the mods list if anyone is wondering there on my build thread.
https://www.cobaltss.net/forums/forc...-build-242945/
Videos will be up later!
No luck today on the Dyno.
under WOT the car is cutting out. I need to find out what is making the car cut out. For some reason my beta version of HP tuners is not reading KR and it seems to be throwing alot of timing... I was not able to make an actual pull on the Dyno i was able to drive it around safely enough to make a few street pulls at around half throttle.
All in all it was a disappointing day! went through 3 sets of plugs and spent some time re-timing the cam sensor hoping that would help.
Damn sorry to hear that man. I am dealing with the cam sensor issue as well, and have been too busy to re time it lol. Keep us posted on what you find out with the cutting out issue!
Talking to Blazin last night he brought up a good point the throttle body may not be opening 100% I need to see I the plate is making contact with the intake manifold if so a little porting might solve the issue!
The t.b hitting wont resolve ure issue unless it litterally not opening up. But a tad.......... I say ure issue is either ure cam sensor, faulty injector or ure idc are to high. timing is incorrect........ Throttle body is a def possible tho... How much timing up top u hitting?
Well from the logs I was going over last night Throttle position around 47% I was seeing 40.5 degrees advanced. 47% throttle was about as high as I got it on the back road I was on. The injectors are brand new I still have my 60's if all else fails.
R u using the stock solonoid for the boost. And post a screetshot or if u want you can send me ure tune ill look at it...... Cali_motocrosser@yahoo.com. It might be a little while im celebrating my new job with my wife and kids lol.......
][/B]
][/B]
