Dyno issues
Dyno issues
So I hit the dyno in my SS/TC for the first time around an hour ago and I had some issues. An SS/SC went before me without issue. When I was on the dyno I shut off the traction control, then I did the calibration run, then I shut off the ESC just to be sure and attempted my first pull. When I was doing the calibration run the ABS light came on, but I figured that was normal. On the first run I pulled from just under 2K rpm up to around 4K when I felt the car/dyno jump a bit so I let off right away. The operator figured it was just the dyno reloading itself at 4K so I did a second pull. At 4.5K this time the car just kinda shuttered and I lost boost and the rpms weren't raising so I stopped. We pulled the car off the dyno after that and I figured I would come on here to see if anyone would have an idea as to why this happened. Also, he operator didn't have the lookup sheet for 2009 so he used the load rating for a 2007, so I'm not sure if that could have been an issue as well. I took it for a ride on the highway after and the car pulled just fine up to 6k. Any ideas?
Mods: K&N sri, and that's it.
it would make sense that the abs got confused because the front wheels were spinning while the emergency brake was engaged. why dont you just do the pull without the brake on? i'm pretty sure they should have your car properly strapped down and secure. then again i never used my emergency brake on a dyno before.
The more I think about it the more I think it was due to my car rather than something with the dyno. Would the traction control engage with the E-Brake on though?
Thanks BYT and everyone for the responses.
So far it sounds like the general consensus is:
I probably won't be able to get on the dyno here again before the semester ends, but the next time I do get on the dyno I will bump this thread and let everyone know if this solved the problem. Thanks again.
- E-Brake can be on or off, it doesn't matter.
- The ESC needs to be off before the car even hits the rollers. (Traction control off isn't enough)
- Clear out any messages. (Ex: Service ABS, ESC, Traction Control, etc.)
