Dyno Results Dyno pictures, videos and dyno results.
Dynoed over the weekend
Old Nov 5, 2009 | 11:54 AM
Bl4des's Avatar
numbers are a little low i think that might belt is slipping a little bit
Old Nov 5, 2009 | 11:58 AM
kburgess04's Avatar
wow yeah that def seems low. maybe try another dynoe and compare. what do you have for a tune?
Old Nov 5, 2009 | 02:11 PM
Bl4des's Avatar
a tune though trifecta
i think i my belt starts to slip around 6300
i didnt have my hahn on when i dynoed i had a 2.5in magnaflow
and i was able to find out how much timing i am running and i am running 26 degrees without any knock but i was told that might be to much what do other people think
Old Nov 5, 2009 | 02:17 PM
lsjwannabe's Avatar
Those numbers are about normal. You are in SAE cf so it gives lower numbers.
If you were belt slipping you would know it. The graph does not show signs of it.
Old Nov 5, 2009 | 02:55 PM
Bl4des's Avatar
i only boost 16.2 psi at max with a 2.8 and vince told me he saw some belt slip on my logs
Old Nov 5, 2009 | 03:06 PM
lsjwannabe's Avatar
belt slip ^
Old Nov 5, 2009 | 03:11 PM
Bl4des's Avatar
so what do you think my problem is. just my tune because i was told that my numbers are low for what i have by the people at the shop and 16 psi sounds to low to
Old Nov 5, 2009 | 03:15 PM
ColeJJones's Avatar
Bannned
yea... my 2.7 was hitting 19.5 at about 7k rpms
Old Nov 5, 2009 | 03:19 PM
lsjwannabe's Avatar
Every car is different but i would not say thats low. Thats about the norm for most cars, your tune could be leaned out a little looks like 11.0 to me across the scale to me.
Old Nov 5, 2009 | 03:23 PM
Bl4des's Avatar
so i should be about 18psi because that is what people are telling. i think i might have a exhaust leak at the header so that could cause it. i need to check to see if the exhaust manifold gasket is still good because i did have an exhaust leak for a wail but i thought i fixed it.
the a/f ratio was about 11.6 11.7
Old Nov 5, 2009 | 09:11 PM
damien's Avatar
You have a header/catback, you won't see 18psi.
My money is on the tune as well.
Old Nov 5, 2009 | 09:16 PM
Perfect.disguise's Avatar
I have full exhaust and I saw 16 on a 2.9.
Jan 12, 2016 12:01 AM
justinchinn
Oct 2, 2015 12:18 PM
maliki778
Oct 1, 2015 07:39 PM
Sep 27, 2015 08:53 PM
