Dyno Results Dyno pictures, videos and dyno results.
Dynotech SS TC 5557 Dyno
Old Mar 9, 2012 | 01:16 AM
InfraRedline's Avatar
Took paintballerr78's car to the dyno today when I went (he had to work so a friend took it).
His mods are the P-Werks 5557 kit with an E47 tune and exhaust.
This was on a Dyno Dynamics Dynotech. For reference they had an HHR SS with GM stage 1 run yesterday and not sure how this works but it made 260whp in 3rd at 19 psi and 282whp in 4th on 25psi. My concern is the boost difference between gears and the high boost on this particular GM stage one, which makes no sense. Anyways that was just for reference. Off the street on 20 psi and 22* timing it made 377whp. We added some timing and leaned the car out a bit since the fuel trims were -7% on the dyno compared to the street. The car made more power as we turned it up but as we hit 23psi it started running out of fuel and wouldnt even make it to redline. I messed with the injection timing and we tried it again. It made it past when the boost came in, but popped a few times in the mid range and cleared up a bit up top resulting in 401whp and 375wtq at 23psi.
I will have him post the graph tomorrow, or see if I can get the pic of the graph from my friend that drove it up, and I have videos ill post too!
Old Mar 9, 2012 | 01:34 AM
paintballerr78's Avatar
Old Mar 9, 2012 | 01:46 AM
There it is! They said they can print out your other runs too. They were nice and smooth with no breaking up, just a few hp less.
Old Mar 9, 2012 | 01:52 AM
matt638's Avatar
nice
Old Mar 9, 2012 | 04:28 AM
Frogstofall's Avatar
Interesting. Do the BNR guys run out of fuel near this power level too? Didn't someone put down ~430whp on a BNR with E47?
Old Mar 9, 2012 | 12:14 PM
Well whether this is true or not, most people say a dyno dynamics reads 10-18% lower than a dynojet. Just some food for thought. Either way it needs more fuel or something, as 23psi isnt enough
Old Mar 9, 2012 | 12:17 PM
TRUF gonna try getting new plugs gapping tighter and check for boost leaks
Old Mar 9, 2012 | 12:21 PM
Yeah get some NGK's and make sure none of the boost leaks came back and if that doesn't fix it, its 5th injector time lol. I dont think there are any leaks though because it spools so nicely and doesnt have crazy STFT's like before.
Old Mar 9, 2012 | 12:22 PM
Brags's Avatar
Nice numbers!!!
Old Mar 9, 2012 | 12:34 PM
jonathan923's Avatar
nice numbers man
Old Mar 9, 2012 | 10:06 PM
cmiller8006's Avatar
At the point your at I think you could make more power on 93 oct, or do like a E30 or something. On the 5857 at 23-24 psi I made 430whp on zzp's dyno for comparison. Nice numbers either way tho.
Old Mar 9, 2012 | 10:18 PM
FrossB's Avatar
Thread Killer
yea i think so too. i made more power on less timing and 91 octane. (2 more psi tho)
Old Mar 9, 2012 | 11:50 PM
I guess that's not bad actually. 3mm smaller turbo and 30 hp.
Old Mar 10, 2012 | 02:18 AM
also the dyno does read off 10% most people say so im not sure
Old Mar 10, 2012 | 02:25 AM
We could try E30 again and see. Bryce made 6 more hp on 3 more psi but on 93, but then again this dyno dynamics may read low. For example I put down 328whp on this dyno, but on a little less dialed in tune I trapped 116 at the track on 26" slicks and nothing taken out of the car.
Old Mar 10, 2012 | 09:27 AM
FrossB's Avatar
Thread Killer
We could try E30 again and see. Bryce made 6 more hp on 3 more psi but on 91, but then again this dyno dynamics may read low. For example I put down 328whp on this dyno, but on a little less dialed in tune I trapped 116 at the track on 26" slicks and nothing taken out of the car.
Fixed
Old Mar 10, 2012 | 12:10 PM
Well see im gonna get plugs next week maybe today and regap them then see what we can do. Hopefully its just plugs and not running out of fuel then if i get deployed...ALLL HELLLLL BREAK LOOOOOOSE
Old Mar 10, 2012 | 12:43 PM
Originally Posted by FrossB
Fixed
Oh yeah you have gas like us, 91 **** water
Fix your radiator first lol had to
He is currently on the side of the road with a broken radiator and im at work on my computer lol
Jan 12, 2016 12:01 AM
maliki778
Oct 1, 2015 07:39 PM
footballplaya3k
Sep 28, 2015 11:14 AM
Sep 27, 2015 08:53 PM
Cptnslo
Sep 24, 2015 09:32 AM
