TVS Dyno
TVS Dyno
Didn't go as planned, with what is done to the car it should have a solid 300whp+ but my car was just not giving the opportunity to work with the tuner. He tuned it very conservatively.
Long story in short, I had installed the methanol kit incorrectly and we fixed that. The fittings then leaked, horribly, we also fixed that. Found out that I had a vacuum leak, we fixed that. Tried using the methanol kit, can't because the controller is a broken piece of ****. He couldn't pull any timing because the car would just constantly knock, gaped the plugs correctly and went some more, still knocking.
Could be bad gas or something else. So anyway, The car is throwing codes, P0420... Hm, is the catalytic converter also a busted piece of ****? I think so.
I'm happy with the people that were there and helped. The tuner did what he could. End of the day I made 276WHP and 242WTRQ.
I think I am going to go the turbo route. I just don't know which setup to go with.
POWER/TRANSMISSION:
TVS with a 2.8"
ZZP 3" Intake
ZZP 3" Exhaust
Bad-mab shorty header
Hahn 3" Downpipe
Siemens 80# injectors
Spec stage 3+ clutch
COOLING:
OTTP heat exchanger
OTTP Dual pass
OTTP Option B
DevilsOwn methanol injection 2.5 bar kit with a 10 GPH nozzle
My DevilsOwn methanol controller is broken. My catalytic converter is clogged. I'm not sure if my valve train had anything to do with it either. My one valvespring is ticking, could that possibly cause the valve to not open and close like it should? I used 91 Octane fuel because it's a DD. I'm going to fix the problems and/ or just part it out and turbocharge it.
TVS with a 2.8"
ZZP 3" Intake
ZZP 3" Exhaust
Hahn 3" Downpipe
COOLING:
OTTP heat exchanger
OTTP Dual pass
OTTP Option B
Based on the cars I've runned it within reason I'd say. I myself would say I'm more around 250-260. Never said it was accurate at all. Just stated what VD claims.
sad you didnt get your car right before going to the dyno. If SSkev is tuning you ,and your car is correctly assembled, he will give you a stellar car. Clogged cat, leaking meth , vacuum leak etc, this is all pretty basic stuff that ,frankly, you should have not even considered going to the dyno in that state. Just go through things, get it mechanically fit, then go to the dyno and tune. We would all like you to post up the good numbers. Good luck.
ps. this has zero to do with TVS; it is all about having a car in proper working order.
As for the OP, get the tune checked out and get those parts fixed. My mod list was...
TVS (stock pulley..3.0 i think?)
60lb injectors
Injen CAI
CIA Header
CIA 3" DP w/ HiFlow Cat
3" Magnaflow Exhaust
Meth injection (75/25, meth/water mix)
CA Heat Exchanger
Ingalls TD
OTTP Stage 2 Rotated Mounts
2 step colder plugs
Tune was set to 11.9 AFR, 26* timing.
287hp and i cant remember the torque.
These problems arose on the Dyno, Powell. SSKev did a great job doing as much as he could. He was extremely patient and I couldn't be any happier. I might as well get some 78# valvesprings, new meth controller, and then hollow out the cat. Then I should see over 300Whp.
Just to let people know, the car did at one point hit 290whp but like I said, my car gave him problems. I'm not upset at all with SSKev, I'm extremely happy with him, we did have a pretty good time other than my car being stupid, lol.
thats why alot of people on the evo forums use VD, its +/- 10hp, which is what a real dyno is going to give you. VD is telling me my car is making 423hp 382trq,I could go on the dyno just outside of the city and it will read ~430hp or i could go to the one 4hrs away and read 400hp. Considering dyno numbers mean nothing at all, ill pick VD and put the money towards more mods. I laugh at people that waste money going on dyno's. The operator that ran my cobalt was ******* around with the settings and my Cobalt made 800+hp. So you tell me whats the difference and how a real dyno is accurate and why it matters....
60lb injectors
Injen CAI
CIA Header
CA Heat Exchanger
Ingalls TD
2 step colder plugs
60lb injectors
Injen CAI
CIA Header
CA Heat Exchanger
Ingalls TD
2 step colder plugs
What you don't understand is that the 800hp reading had nothing to do with how accurate the dyno read your pull. It was all based on the settings in the computer that runs the dyno. It's pretty common knowledge that the parameters have to be set for each car and someone that doesn't know what they are doing will get numbers like that.
One shop I went to spent half an hour getting mine right. My first dyno pull read something like 1032 ft/lbs at the wheels and like 800 something whp. It just took some tweaking and settings adjustments until it read correctly.
Personally I don't have a problem with virtual dyno numbers so long as you're comparing them to other virtual dyno numbers. Apples to apples ya know...
People are so fast to give up on a setup when the dyno numbers they see are not what they wished for.
Same thing would have happened with a turbo setup. If the car is not mecanically sound, expect low numbers.
Good luck with getting everything straightend out though.
yup which is why my car only lost by 1/4 car against a built motor (2.2 lsj) ported head tvs car on 23+ psi.
m62 and e85 on my car stock everything else (well header and airbox mod)
I'm surprised how many people get caught up in the number game on dynos. Unless you are using it to tune a car, that final number means nothing. I spent 5 hours the other week at a local dyno manufacturer trying to work out a deal for a 24" roller with a eddy current unit on it. People concerned with just Dynojet and Mustang dyno's really don't understand that there are better options out there to get their dyno "numbers". Dynojet for instance has there "true number" system which essentially is a flywheel HP calculation. That's why Dynojet numbers are always higher than mustang.
All the problems that arose were completely my fault and I accept that. I'm not upset, I have the car parked and am currently returning it back to the way I bought it to purchase another vehicle. I am not financially fit at the moment to be toying around with the car. I really would love to but there are other things in life that come first.
I will definitely miss the car when I sell it. I don't want to give up. I kind of have to, at the moment it's a money pit and I'm trying to get out of debt... School won't pay itself.
PS - For the record, SSKev not only stayed longer than he had to but he tuned it after we fixed the problem so that I could get home. In my eyes, very stand up guy. I would highly suggest anyone to go to him. I wish I had a mechanically fit car at the time.
Thats my whole point. No two dyno's are going to have the same settings, therefor, read the same. What is the difference between setting the settings for a car on a dyno and then setting the settings on VD. Unless your car is a dyno queen, the numbers mean nothing. Sure its cool to know what the car is making but does it really mean anything? The only thing a dyno is good for is tuning to see the curve, afr and boost. And for me personally there are only 2 AWD dynos i can go to. One of them is 1-2 hours away and i refuse to do buisness with him. The other is 4 1/2 hours away. $125 for 3 dyno pulls + $70 gas to get there, $70 gas to get home and $20 for lunch or food while im there....defently not worth it if VD is telling me my numbers and is only off +/- 10hp (which is what the 2 dyno shops will read differently anyways)
