Dyno Results Dyno pictures, videos and dyno results.
TVS Dyno
Old May 22, 2012 | 11:23 PM
Bluelightning's Avatar
Got Bewst?
Originally Posted by DarkChild
POWER/TRANSMISSION:
TVS with a 2.8"
ZZP 3" Intake
ZZP 3" Exhaust
Bad-mab shorty header
Hahn 3" Downpipe
Siemens 80# injectors
Spec stage 3+ clutch
COOLING:
OTTP heat exchanger
OTTP Dual pass
OTTP Option B
DevilsOwn methanol injection 2.5 bar kit with a 10 GPH nozzle
My DevilsOwn methanol controller is broken. My catalytic converter is clogged. I'm not sure if my valve train had anything to do with it either. My one valvespring is ticking, could that possibly cause the valve to not open and close like it should? I used 91 Octane fuel because it's a DD. I'm going to fix the problems and/ or just part it out and turbocharge it.
I'm running similar mods to you except I'm on a 2.9" pulley. So far I've made 308whp and 285wtq with a 10gph nozzle but was getting knock in the tune. Thought I should be able to push it a little further. After some research I've found the 91 octane to be holding me back a bit. Most people in the states have 93 octane. So I ordered a 14gph nozzle to help compensate for it. Should be here any day now then I'll be out to retune. Something to keep in mind.
Originally Posted by 05Slowline
fake dynos don't count all you people touting virtual dyno thinking it's accurate are hilarious.
When I was on my M62 my friend uses a virtual dyno for his legacy gt because an awd dyno is nowhere close to us. Well he ran my hpt log and it was 2 whp and 3 wtq off what I made on and actual local dyno. So I would say they are fairly accurate. But there are lots of factors I'm sure that come into play.
Old May 22, 2012 | 11:26 PM
Chevycobaltss3's Avatar
Why so low in power ?
Lightening
Last edited by Chevycobaltss3; May 22, 2012 at 11:26 PM. Reason: Automerged Doublepost
Old May 22, 2012 | 11:30 PM
Got Bewst?
Lightening
Me?
Old May 23, 2012 | 12:03 AM
srt-10's Avatar
apparently you think it does cause you advertise fake numbers in your sig lulz
well how about this. You send me $250, ill go dyno the car, so i can post up numbers that will read 10hp difference? Will that make you happy?
Old May 23, 2012 | 01:46 PM
nizzle's Avatar
Not taking sides at all but, DAMN! $250 for dyno runs up there? $90 is about average for around here. Maybe upto $150 at some "snooty" places.
Old May 23, 2012 | 02:00 PM
srt-10's Avatar
like i said in another post, its not just for the runs. Theres only 2 AWD dyno's near me. Theres one about an hour away but i refuse to do buisness with them. The other is 4 1/2 hours away. So about $70 in gas there, $70 in gas to get home, $125 for the dyno and then lunch, its 250+ just to go on a dyno and do 3 pulls to show me numbers that VD will show me. Yea sure its cool to know what the numbers are on my car, but i dont get hung up on them. How the curve is on the dyno is more important and how the car performs on the track is
what i care about. VD already helped me with finding out my clutch was starting to go...
Old May 23, 2012 | 02:07 PM
nizzle's Avatar
Oh ok. I understand
Old Jun 2, 2012 | 05:58 PM
DarkChild's Avatar
That's what happens when you run it without a tune for too long. It's my fault as to why it didn't make the power it should have made.
Old Jun 2, 2012 | 06:02 PM
SunburstSS's Avatar
Do you happen to have solid mounts man ?
Old Jun 6, 2012 | 02:25 PM
DarkChild's Avatar
I've got solid mounts. I'm selling them. I just need to find my stock set first.
Old Jun 6, 2012 | 02:30 PM
  #36
Staged07SS's Avatar
Administrator
Administrator
The braided flex warp is not due to running w/o a tune....
It just so happens those cheap type of flex joints do not handle forced induction cars very well.
Although, the warped flex will choke the exhaust flow off, and cause the car to run rich (happened to me with a Random Technology downpipe).
I refuse to run anything but a lined (interlocking) flex section on my car due to this.
Old Jun 11, 2012 | 09:12 PM
  #37
DarkChild's Avatar
I thought Hahn was a quality part. You sure pay a lot for the thing. If that flex pipe caused me to run richer then that would explain why the converter is junk too.
Old Jun 12, 2012 | 07:17 AM
  #38
Staged07SS's Avatar
Administrator
Administrator
When you start running rich, you dump unburnt fuel into the converter.
Spun metal cats are notorious for melting due to an overly rich condition.
When I had the Random Tech downpipe (same as the hahn), the braided flex warped, choked off my exhaust, and caused my car to run super rich. My plugs were fouled out, and the cat slipped within its casing meaning it was over heated.
Old Jun 13, 2012 | 02:04 PM
  #39
DarkChild's Avatar
EXACTLY what happened to my car. So if I made the power I made with my problems. It should show people how much the downpipe can affect the car.
I'm saving for the ZZP S256ET turbo setup. Going catless this time around. Come time for when I have to do an emissions test I will have a custom made catted pipe.
Shooting for 400+Whp. Was going to sell the car but some people think their cars are worth more than gold.
Old Jun 17, 2012 | 05:48 PM
  #40
bratboy90's Avatar
Lots of good info in the silly thread. haha
Old Jun 17, 2012 | 10:21 PM
  #41
DarkChild's Avatar
I knew while trying to tune the car that the downpipe was trash but I didn't know that would cause it. Learned something new.
SmitBag
Sep 7, 2016 08:05 AM
Jan 12, 2016 12:01 AM
maliki778
Oct 1, 2015 07:39 PM
SSLOW06
Oct 1, 2015 07:21 PM
Sep 27, 2015 08:53 PM
