Dyno Results Dyno pictures, videos and dyno results.
TVS E85 Dyno
Old May 25, 2011 | 11:02 PM
  #76
alleycat58's Avatar
Originally Posted by Area47
someones pissed because he is slower and puts down less power.
ws, there are a couple tricks inside the map itself to squeak some more out
Now he gets to figure out dino fuel tuning on the BRFS for some real track time on Sunday. As long as nothing else breaks or goes wrong before then. Will be the first one-wheel adventure on the TVS.
Old May 26, 2011 | 05:07 AM
  #77
thedubsack85's Avatar
I did give him credit where it was due im not a hater ive been here to long for that, I complimented him on his trap and E.T, BUt having a Gmpp exhaust and a Non factory D/P is not a stock exhaust, No matter how you word it, Just asked he be correct in his mods listed.. So that there are not people that all of a sudden think ZOMG i can run a factory exhaust with a TVS AND E85 i saw it on the forum!!!!! Ya know what that will lead to? More blown motor threads than ever. But i know nothing...
Old May 26, 2011 | 08:55 AM
  #78
WSFrazier's Avatar
If someone is stupid enough to mod their car based around someone's signature on an internet forum, their **** deserves to blow up.
Old May 26, 2011 | 10:49 AM
  #79
Witt's Avatar
This website has lost more engines to catalytic convertors and mufflers than any other site.
True story.
Old May 26, 2011 | 06:08 PM
  #80
383_Stroker's Avatar
LOL
Old May 27, 2011 | 10:29 PM
  #81
BLue NoTe's Avatar
Originally Posted by Witt
Area was laughing because he gave Wes the base spark map used on the dyno and track and someone called Wes a tuning god.
We all know Area is a god, I didnt have to point that out
Old May 27, 2011 | 11:42 PM
  #82
Area47's Avatar
Rent me! per hour
im his other son. craig
witt = jeasus
06black = mary
ws = joeseph
Old May 28, 2011 | 01:19 PM
  #83
witt = jeasus
06black = mary
ws = joeseph
TROOF!
Old Jun 6, 2011 | 09:46 AM
  #84
WSFrazier's Avatar
Figure this is the best place to put this.
Went to the track last week, 2nd misfired at the top, and all of 3rd was total misfire too. Only managed 12.9@108 with half of 2nd, and all of 3rd useless. One run I actually hit the brakes before I even crossed the trap because it was misfiring so bad, still managed a 13.3@90 somehow lolol. I also had 0 traction even with slicks, boost control apparently wasn't working.
Turns out, I blew the vac line off my boost bypass solenoid, which explains the bad launches, but I also had my fuel regulator tee'd into that same line :/ I was missing about ~25psi of fuel pressure on all my runs, ooops. Knock sensor didn't pull any spark at all, car was detonating so bad on the high timing map (28ish* advance up top), that it nuked my plugs pretty good. This was my end result:
I guess still running 12.9 with this and 0 fuel gives me hope for decent times once I go back, also running low 13s while hitting the brakes had me laughing pretty good.
Old Jun 6, 2011 | 10:45 AM
  #85
shroogis's Avatar
I would do a compression test. Every time I've broken a plug like that it's resulted in a busted piston (and pistons that are way stronger than stock LSJ ones, too)...
That doesn't look great, so good luck to ya.
Old Jun 6, 2011 | 10:49 AM
  #86
WSFrazier's Avatar
Yeah I should of mentioned, motor is still in great shape.
If this would have happened on dino fuel, piston more than likely would of been damaged. My old Cobalt blew a ringland from a lot less.
E85 is literally holding the motor together, IMO.
Old Jun 6, 2011 | 02:20 PM
  #87
InfraRedline's Avatar
That plug got rick rolled! Its amazing the motor held together on base fuel pressure with that much boost and timing. I cant even imagine how lean that would have been lol
Old Jun 6, 2011 | 05:30 PM
  #88
alleycat58's Avatar
He needs it. He will be tortured rigorously if there's something wrong with that motor.
Old Jun 7, 2011 | 09:05 PM
  #89
Area47's Avatar
Rent me! per hour
phone call was placed by someone, lawls here had
Old Jun 8, 2011 | 09:40 AM
  #90
WSFrazier's Avatar
Only because he is getting nervous that someone is faster.
BTW, how do you retard timing more than -10, no matter how much I do, it won't run less than -10, even with adder tables.
Old Jun 9, 2011 | 05:53 PM
  #91
Area47's Avatar
Rent me! per hour
tryin to shoot fyrebalz?!?!
Old Jun 10, 2011 | 08:54 AM
  #92
WSFrazier's Avatar
-10 will get some cinder shooting fireballs, but isn't consistent enough. Thinking -20 will get it done. Someone needs to scare the ricers on the street.
Old Jun 10, 2011 | 12:10 PM
  #93
zrated89's Avatar
looking forward to the track results next time. When you were running mid 12's was it on this timing map and tune last year or has she been tweaked some for this year?
Old Jun 10, 2011 | 01:50 PM
  #94
WSFrazier's Avatar
I honestly can't remember. I don't think I ever got a chance to run at the track with this map, besides this year where I lost fuel pressure and blew a plug.
Having an open diff is really starting to kill me now, though. It's an uphill battle at this point. I was hoping for 12 flat and MAYBE an 11.99, but I don't think I will get the traction for a 1.7 60' to do it.
Old Jun 10, 2011 | 03:14 PM
  #95
zrated89's Avatar
Yea my car came without it i then bought a limited slip one and installed the gmp clutch. Anxious to see what i cut on slicks. I cut almost a 1.9 on street tires and factory 18s
Old Oct 1, 2011 | 04:26 AM
  #96
dcoll177's Avatar
Did you ever put that header/dp on and hit the Dyno again?
Old Oct 1, 2011 | 07:50 AM
  #97
alleycat58's Avatar
Header/DP is on, but the car has not been back to the dyno. It's got a bad coil pack that's causing issues, once that's fixed I'd love to get it back on the dyno though.
Old Oct 1, 2011 | 01:35 PM
  #98
dcoll177's Avatar
I'm in for some Dyno numbers with that exhaust on. I plan on doing tvs with e85 and I still haven't bought an exhaust but if your seeing 350whp on a pretty much stock exhaust I might hold off on spending big bucks on some 3in tubing. What pulley were you running and what kind of boost were you seeing? Stock tb or ls4?
Old Oct 1, 2011 | 08:32 PM
  #99
alleycat58's Avatar
Stock TB, 2.7" pulley. I don't remember the boost.
Old Oct 31, 2011 | 12:26 PM
  #100
zrated89's Avatar
hey wes ran my car yesterday. 12.40@113. 2.7 pulley like on your runs. whats was the fastest you ran before your issues? i know your sig says mid 12's im just curious. I had to shift to fourth before the trap and was only on the 93 tune so im happy where its at. First time running on slicks and the TVS as well i believe i can shoot for the same goals you are with some race gas and more timing. I can only run 21-22 on meth before seeing some trace knock
