Dyno Results Dyno pictures, videos and dyno results.
TVS E85 Dyno
Old Apr 17, 2011 | 01:00 PM
WSFrazier's Avatar
Originally Posted by skatin_boarding
Ah I see. I finally got mine running 100%. Thanks for all the help you lended. Turned out I had a flop of a fuel pump. Replaced it with another 342 and all the problems went away. Im going to try to slap on the 2.6" today.
Good to hear, my ZZP kit is still working great.
I have a 2.5" ring I would of liked to slap on for *****, but no time to do so between runs. Plus I don't think it would of changed my numbers, just move the curve around.
Old Apr 17, 2011 | 08:59 PM
IonNinja's Avatar
what downpipe?
Old Apr 24, 2011 | 04:20 PM
383_Stroker's Avatar
Thats Hella timing you got there .. I like it
Old May 9, 2011 | 11:21 PM
Corvettespirit's Avatar
GRABBER BLUE MUSTANG GT
very nice and impressive numbers WS!
Old May 12, 2011 | 02:10 PM
2K5SS/SC?'s Avatar
That poor car is begging for a bigger exhaust though! Damn nice numbers reguardless. Once again the old school players are still out there proving they still got it.
Old May 12, 2011 | 02:14 PM
WSFrazier's Avatar
One of these days I will find a used/cheap header on here someone is selling. Otherwise it's probably going to stay where it's at unless something breaks.
But my time/money is going into small suspension tweaks, and other wise my little Honda. I want to start tinkering with my Del Sol.
Old May 12, 2011 | 02:23 PM
tylerjclance's Avatar
USA Y U NO HAVE AUTOBAHN?
third gear??
why do third and not fourth?
i'm not dyno savvy :p
Old May 12, 2011 | 02:26 PM
WSFrazier's Avatar
Mainly because I had snow tires on and they aren't rated for that speed.
On a blown, manual car... Gear does not matter.
Old May 12, 2011 | 02:30 PM
so it would have been the same result in second or fourth is what you're saying??
I'm just curious
Old May 12, 2011 | 02:31 PM
nizzle's Avatar
WE NEED some ****** E85 in SEATTLE!!!!!
Old May 12, 2011 | 05:35 PM
  #36
I'm just curious
Just my experience:
3rd Gear versus 4th
Old May 12, 2011 | 05:39 PM
  #37
Perfect.disguise's Avatar
I'm just curious
No, 4th would have provided lower numbers. You always want to dyno in your closest 1:1 gear and that is your 4th. STD correction will also produce higher numbers than SAE.
Old May 13, 2011 | 08:36 AM
  #38
WSFrazier's Avatar
It really depends on the car's setup.
If you have a big turbo, you will want at least 4th, if not 5th, to really load up that turbo.
On an N/A or Blown car, it really won't matter. The guy that posted the above chart is proof.
Old May 13, 2011 | 09:01 AM
  #39
Staged07SS's Avatar
Administrator
Administrator
When you say stock exhaust.... are you still running the stock downpipe as well? I know you have the GMPP catback & stock manifold.
Old May 13, 2011 | 09:08 AM
  #40
WSFrazier's Avatar
Yeah I forgot to mention cat-delete. Forgot about that :/
Old May 13, 2011 | 09:13 AM
  #41
Staged07SS's Avatar
Administrator
Administrator
Cat-delete on the stock downpipe? Or aftermarket? JW
Old May 13, 2011 | 09:18 AM
  #42
alleycat58's Avatar
It's a Vibrant catless dp.
Old May 13, 2011 | 09:19 AM
  #43
WSFrazier's Avatar
No, it's a cheap Cobalt Addiction D/P, I think.
It was laying in a buddies garage, not exactly sure. 2.5".
Old May 13, 2011 | 09:23 AM
  #44
Staged07SS's Avatar
Administrator
Administrator
gotcha.
nice numbers for so little modifications & exhaust setup!
Old May 13, 2011 | 09:28 AM
  #45
Maybe thats the magic set-up...
Long ago I had exactly that exhaust set-up on my 2.85 pulley m62 and did 276 horse.. :P
Old May 13, 2011 | 12:34 PM
  #46
alleycat58's Avatar
Could have sworn we were joking about it being a Vibrant DP when it was off the car for inspection last year.
Old May 13, 2011 | 01:29 PM
  #47
Cobalt addiction uses vibrant flanges if i recall correctly.. something on them says vibrant
Old May 13, 2011 | 01:49 PM
  #48
Staged07SS's Avatar
Administrator
Administrator
Yep, they use Vibrant flanges & cats.
Old May 13, 2011 | 02:10 PM
  #49
alleycat58's Avatar
That would explain it, I know the DP says Vibrant on it, that's what made me think that's what it was.
Old May 13, 2011 | 03:17 PM
  #50
5th gear dyno's? So many 3rd vs 4th comparisons on this site have 3rd reading higher. I would read alot higher in 3rd than I would in 5th.
