Dyno Results Dyno pictures, videos and dyno results.
Wert842 finally got on a dyno...
Old May 27, 2014 | 09:44 AM
Terminator2's Avatar
Awesome numbers man! My attempt at getting numbers failed last Saturday when my car suddenly decided to go lean at 3800rpms in 4th gear. Term already made me a new tune file, but I won't be able to run a log until next weekend since I'm on the stock down pipe right now so I can pass emissions this week.
Then I'll go back. This is a Mustang dyno btw. Will probably also be fine tuning there before going back to the road track.
It was making around 400 wrtq and climbing fast at 4000 RPMs on the mustang dyno when it cut out. It will make more next time and should have no issues.
Old May 27, 2014 | 09:59 AM
Originally Posted by Wert842
Export, pa is like 1,000 ft above elevation. Correction factor came into play cause of it being indoors with no air circulation, like 93 degrees, 62 degrees humidity, and barometric pressure of 27 around 1pm. It was hot as all hell in the by the dyno. Just standing there you would sweat your ***** off. It was kind of a spur of the moment thing. Lsj-t before me made 337/315 with the correction factor.
Being it was a dynojet some may say they are high and inflated but their dyno measures only 6% higher than a mustang dyno like 15mins from where I dyno'd. Even then it'd still be around 418/380ish. Very good numbers regardless. I'll eventually take it back down on a cooler day to see what the results will be.
What turbo and what boost level and fuel was the LSJ-T running?
Old May 27, 2014 | 10:37 AM
InfraRedline's Avatar
Solid numbers man, congrats! That's a well balanced car for sure.
Old May 27, 2014 | 12:20 PM
Wert842's Avatar
I was in a ride in an LNF making very similar numbers last week. Definately awesome! Congrats because i know hmthat those are really solid numbers and that makes for a serious car
It definitely pulls and pulls. Its a monster.
93 on a holset h1c hx35 on 22psi iirc. He was still on 60s and his fuel was giving him issues horribly.
445 whp with only 404 wrtq so there is no boost spike it builds nicely. I just have his wg ramp down perfectly for the turbo. I knew I had something special when he ripped off a 3.6 second 60-100 93.
Should definitely take pride in tuning it man. Shocked a ton of people. No one expected it. Haha. I did crank out a 3.48 iirc on one of my pulls a while back.
Yes sir. Thanks man. It is a fun summer dd. Haha.
Old May 27, 2014 | 02:33 PM
Yeah when I saw that you made more on 93 than most do on E-47 I was stoked. I knew it was fast and yes I believe I have a 3.48 60-100 log from you. Once you get the meth injection hooked up I should be able to squeeze another 30 whp out of it without touching anything but the timing same PE lambda same wg tables same DALs, MALT,etc.
Old May 27, 2014 | 02:42 PM
I forget, is this car on the stock fuel system components as well?
Old May 27, 2014 | 02:55 PM
Yes completely stock engine and fuel system. Just a couple bolt ons and the ZFR and 93 octane. He has a meth kit he will be hooking up soon to hopefully add another 30 whp at the same boost level he is running now.
Old May 27, 2014 | 03:48 PM
That's what I thought. Would be awesome if Wert had access to E85 and had a few fueling mods and could push for 500!
Old May 27, 2014 | 04:24 PM
I think it will be close to 500 whp with the meth injection. I forget which size nozzles his kit came with but I told him to use the big one LOL.
Old May 27, 2014 | 04:40 PM
Go big and crank some timing into it lol. And maybe a little something that rhymes with schtirty poundsh
Old May 27, 2014 | 04:52 PM
  #36
Old May 27, 2014 | 04:55 PM
  #37
Wert842's Avatar
Ya wtf. This thing is already nuts. I wonder how its gonna be with the meth injection.
Old May 27, 2014 | 04:59 PM
  #38
Thirty pounds (of boost)
Old May 27, 2014 | 05:01 PM
  #39
Wert842's Avatar
Scurrrryyyy
Old May 27, 2014 | 05:45 PM
  #40
Nah 28 psi is high enough on his stock motor. As far as extra power I will not touch anything but the timing when he gets the meth on. That way he can see if the meth was worth it.
Old May 27, 2014 | 05:48 PM
  #41
Yeah on a stock block 28 lbs is probably plenty, I just like to get people to poke the bear with a stick a little more lol. The meth will definitely help. At his airflow levels you will really see the gains from each degree of timing.
Old May 27, 2014 | 07:52 PM
  #42
taintedred07's Avatar
You've gotta be the highest whp zfr on 93
Old May 27, 2014 | 08:10 PM
  #43
Wert842's Avatar
I'm still waiting for Devils own to send me another self sealing fitting cause mine didn't hold the line. Every time it became pressurized it blows the line out of the fitting. I will be using the 7gph right after the elbow in a lower cp. It'll be grand!
I like playing with fire and what not too, but it needs to hold off a bit until I get my new toy...
Lol. I'm pretty sure I am without a doubt. Especially one with stock top and bottom end and just bolt ons. I'm proud of the little 2 liter of soda really.
Old May 27, 2014 | 08:24 PM
  #44
15 cars? Damn lol it would be cool if Fran did a dyno day for just Ecotecs sometime.
Old May 27, 2014 | 08:45 PM
  #45
Wert842's Avatar
Fran said he's been super busy with the Mazda group cause he just recently became the owner of protégé garage and those guys are demanding a big market. He said he has really lost touch from his roots of the ecotecs. We could easily get a group of ecotec guys to go down and show him what he's missing! I know of 3 that would definitely join me to head on down. Hopefully you and Bryan would go too. Possibly Corey if he gets his car fixed. Frans only an hour or so from me, so I'm game whenever. Haha.
Old May 27, 2014 | 08:55 PM
  #46
Hell yeah, in addition to Bryan and Cory at least 2 or 3 other guys from around Pittsburgh would go so I'd say we could get 10 Ecotecs down there.
Old May 27, 2014 | 09:05 PM
  #47
Wert842's Avatar
I'm down!
Old May 28, 2014 | 09:22 AM
  #48
willdrew's Avatar
Impressive Great number!
Old May 28, 2014 | 12:21 PM
  #49
climb385's Avatar
fran at fj is a great dude, does amazing work with gm cars and i can dyno the car without 2nd gear!!! lol or ill just bring the bike down! lol
Old May 28, 2014 | 01:04 PM
  #50
Dyn0mitemat's Avatar
I'd be interested in going depending on when
