Dyno Results Dyno pictures, videos and dyno results.
ZFR Dyno Results Finally :)
Old Mar 28, 2013 | 01:00 PM
SunburstSS's Avatar
Talking ZFR Dyno Results Finally :)
So today I went with my buddy Sean to get my ZFR set up on the dyno, the current mods that count are :
ZFR Turbo
ZZP Catted Downpipe
ZZP Full Intercooler Package
Stock Intake With K&N Filter
Stock Clutch
Stock Exhaust
Car was tuned with extreme reliability in mind by an awesome local tuner, didn't go all out with the tune so my numbers reflect that. I had the boost to ramp in slowly and it worked out well, Boost is set to 22-23 up top and timing is only up to 15 degrees.
We have a lot of room to grow, I need to figure out a solution for the stock intake tube, I tried putting the zzp intake tube on but it didn't fit and wont fit for shyt lol...Thanks ZZP , Timing and boost can be turned up to 25-26 psi which is where the zfr appears to wake up from the logs that I have done but I don't know when I will be waking it up never the less it pulls hard
A Stock SS/TC dyno'd there at 230whp/220wtrq
The Numbers were : 355whp/327wtrq
Dyno Sheet :
Dyno Video :
574's Avatar
574
First, nice numbers Is it just me or is the tq a little low?
Old Mar 28, 2013 | 01:09 PM
AARON-SS-TC's Avatar
That must be a very conservative tune.
So glad you are happy though.
Old Mar 28, 2013 | 01:10 PM
vahdyx's Avatar
Very nice man!!! I'm making 360whp with the K04+ but maxxed out and since you're on a conservative tune making what I make maxed out that's awesome! I may have to try that and shoot for one or two PSI more than you.
Old Mar 28, 2013 | 02:28 PM
Silverbullet33's Avatar
nice to finally see #'s for a conservative zfr
Old Mar 28, 2013 | 02:54 PM
alerosaint's Avatar
Good numbers for such a conservative tune.
Old Mar 28, 2013 | 04:36 PM
SunburstSS's Avatar
Correct, that is usually common with bigger turbos from what I seen, also the way its tuned commands for a bit lower torque numbers to avoid spinning out, breaking traction is no fun in higher speeds
Yeap Yeap, I can easily modify some stuff and get up to 380 maybe 400whp area
Aaron ! Buy a turbo already lol
Thank you sir I might be pushing a lil bit more power in the future but now I need it to be extremely reliable for the next month or so
It seems that a lot of people that get a bigger turbo try to max it out right away, I'd rather do it in stages if I'm going to, but reliability is a big factor for me now
And it still makes power all the way to the top and the torque doesn't drop that much at all
Old Mar 28, 2013 | 04:39 PM
Fastgti69's Avatar
Nice numbers man.
Old Mar 28, 2013 | 04:45 PM
Stamina's Avatar
Congrats man! Glad you're enjoying it. That's a very healthy improvement over your stock numbers, especially on a conservative tune. lol
Old Mar 28, 2013 | 04:58 PM
willdrew's Avatar
cant wait to get mine!
Old Mar 28, 2013 | 06:52 PM
SunburstSS's Avatar
Thanks guys, the ZFR is awesome overall, and well worth the money, the fact that I can push it more is always a plus
Old Mar 28, 2013 | 06:57 PM
Wert842's Avatar
Ah ya. Nicely done. Who tuned it?
Crank it up a bit. I wanna see what it takes to get to 380-400 on 93 and full bolt ons.
Old Mar 28, 2013 | 07:06 PM
mike1coolguy88's Avatar
my results of my zfr
mods
autowerks street intercooler
autowerks lower charge pipe
clear image upper charge pipes
3 bar sensors
turboxs down pipe and exhaust 3" straight piped muffler
autowerks valve springs
zzp rotated trans mounts
tune was amazing by dave at performance auto works pulls super hard
and smooth
dyno 389hp/379 ftlbs 93 octane
advise's Avatar
Nice numbers bud
Miss the tvs at all? Lol
Old Mar 28, 2013 | 07:17 PM
SunburstSS's Avatar
I would say 26 psi , another degree of timing or two and replace the stock intake tube and I should be around that area for sure
My buddy Sean did, I just fine tuned the boost and timing the way I want it
mods
3 bar sensors
and smooth
Very nice dude I likey
Originally Posted by advise
Nice numbers bud
Thanks man ! I'm not gonna lie I do miss the TVS lol, I miss the whine whine man !
Old Mar 28, 2013 | 07:19 PM
mine is on 24psi its insane dude pulls like a frieght train and the stock clutch dont like it lol
so clutch will be goin in a week once i decide which clutch im doing
then drag radials
Old Mar 28, 2013 | 07:22 PM
SunburstSS's Avatar
then drag radials
lol damn I bet haha, Im still on stock clutch too, but so far my clutch is not complaining I don't know whats gonna happen when I turn the dial up a bit lol
Old Mar 28, 2013 | 07:32 PM
Wert842's Avatar
mods
3 bar sensors
and smooth
Sounds perrrrfect. Any more info on the tune timing, boost, and what not?
Old Mar 28, 2013 | 08:24 PM
Shortbus's Avatar
Nice to see numbers like this, will be something i would like to run around on #'s wise for a DD tune.
Old Mar 28, 2013 | 08:42 PM
09BlueBaltSS's Avatar
Nice curve. What were u seeing for lb/min??
Old Mar 28, 2013 | 08:58 PM
SunburstSS's Avatar
My thoughts exactly
I am getting 38.3 lbs./min at 22.8 psi and during some logs I playing with the boost I got 40.5 lbs./min at 24.8 psi
Old Mar 28, 2013 | 09:41 PM
Is that skewed at all? I'd expect more on the 375whp side maybe needs another degree or two of timing?
Old Mar 28, 2013 | 10:29 PM
SunburstSS's Avatar
As far as I know everything is working properly and is working properly, I will be pushing it a bit more in the future just not sure when , a couple of degrees will help for sure.
On another note I posted the dyno video
Old Mar 28, 2013 | 11:15 PM
Stamina's Avatar
mods
3 bar sensors
and smooth
How'd you get that CIA hotside to fit? I couldn't find a 2"-to-2.5" reducer in anything longer than 2" after scouring the Internet, so the only options I could figure were to either lengthen the turbo mouth or lengthen the hotside a few inches to meet the turbo.
Old Mar 28, 2013 | 11:33 PM
SunburstSS's Avatar
Hey bro, check this site out, they have a wide collection of silicone couplers, reducers and joiners, u might be able to get a joiner as an extender
Intercooler Pipe Fabrication - Silicone Intake Systems Auto Parts
