*OFFICIAL* Torque App Mod's
Old Jul 30, 2013 | 04:35 PM
  #51
Sox-Fan's Avatar
Got Brakes?
For real, lol. It's Android only.
Old Jul 30, 2013 | 07:54 PM
  #52
wol-shiver's Avatar
hi guys,
08 stage 1 lnf with catless, injen charge and k&n shortram.
i cannot seem to get my ltfts to read, but my stfts do.
lazy sensor?
what do you think of the log?
est report:
MID:$01 TID:$83
- O2 Bank 1 Sensor 1
Max: 1.99882 Min: 0.29988
Test result value: 0.93306
PASS
MID:$01 TID:$84
Max: 0.06997 Min: -0.06997
Test result value: 0.00354
PASS
MID:$02 TID:$01
Rich to Lean sensor threshold voltage(constant) - O2 Bank 1 Sensor 2
Max: 0.64026V Min: 0.64026V
Test result value: 0.64026V
PASS
MID:$02 TID:$08
Maximum sensor Voltage for test cycle(calculated) - O2 Bank 1 Sensor 2
Max: 1.14778V Min: 0.44969V
Test result value: 0.91939V
PASS
MID:$02 TID:$66
Max: 20,487 Min: 6,216
Test result value: 65,520
FAIL
MID:$02 TID:$81
Max: 0.64026V Min: 0V
Test result value: 0.6305V
PASS
MID:$02 TID:$82
Max: 1.14778V Min: 0.64026V
Test result value: 0.65002V
PASS
MID:$14 TID:$80
Max: 80Ohm Min: 1,296Ohm
Test result value: 32,770Ohm
FAIL
MID:$21 TID:$84
- Catalyst Monitor Bank 1
Max: 1.99882 Min: 0.20301
Test result value: 1.03066
PASS
MID:$39 TID:$80
Max: -4,915 Min: -32,768
Test result value: -5,043
PASS
MID:$3c TID:$80
- EVAP Monitor (0.040")
Test incomplete or dependant test failed
MID:$3d TID:$88
- EVAP Monitor (0.020")
Max: -10 Min: -32,768
Test result value: -59
PASS
MID:$3d TID:$8c
Max: 32,767 Min: -8,192
Test result value: 7
PASS
MID:$41 TID:$85
- O2 Heater Monitor Bank 1 - Sensor 1
Max: 1,302.80005°C Min: 805°C
Test result value: 819.90002°C
PASS
MID:$42 TID:$81
- O2 Heater Monitor Bank 1 - Sensor 2
Max: 754Ohm Min: 0Ohm
Test result value: 132Ohm
PASS
MID:$81 TID:$80
- Fuel System Monitor Bank 1
Max: 6.04% Min: -6%
Test result value: 2.01%
PASS
MID:$81 TID:$82
Max: 1.31925 Min: 0.77958
Test result value: 1.01263
PASS
MID:$9f TID:$da
Max: 22,555 Min: 6,176
Test result value: 9,672
PASS
MID:$a2 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 1 Data
Max: 65,535Count Min: 0Count
Test result value: 1Count
PASS
MID:$a2 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 1 Data
Test result value: 3Count
PASS
MID:$a3 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 2 Data
PASS
MID:$a3 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 2 Data
Test result value: 9Count
PASS
MID:$a4 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 3 Data
PASS
MID:$a4 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 3 Data
Test result value: 6Count
PASS
MID:$a5 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 4 Data
PASS
MID:$a5 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 4 Data
Test result value: 10Count
PASS
End of report.
Old Jul 31, 2013 | 08:21 PM
  #53
cobythecobalt's Avatar
That SUCKS!!!
Old Jul 31, 2013 | 09:08 PM
  #54
sLAsh's Avatar
Outside of box thought
People have been able to get the standard version of hptuners to read a wide band by sending the data through the air conditioner sensor. Could the same thing be possible with torque. I see a pid to read the air conditioner high pressure sensor. Could we have a wideband for just the cost of a sensor?
Old Mar 2, 2014 | 08:09 AM
  #55
BlackyK's Avatar
Torque is saying the "Catalyst" is incomplete and I have P0107 lean bank 1. I've replaced maf, vapor canister, hose clamps in the intake, and 3 hoses that were split etc. What's next??
Edit: I think I may have a lead here. O2 Bank 1 volts are bouncing from .1v to .8v. O2 Bank 2 volts are very steady at .1v to .15v. Think the first O2 sensor is blown?
Old Mar 2, 2014 | 08:50 PM
  #56
serega12's Avatar
I think you'd have better luck posting this in actual engine subcategory, this is more like the mods to the actual app. just sayin...
Old May 15, 2014 | 10:10 AM
  #57
ShitBoxSS's Avatar
I am having trouble with the IAT2 PID. I entered it in just like it said and it worked fine for about 2 weeks then it would only work for the first couple of minutes I was running torque and just wouldnt refresh. Now it wont show a number at all and when I went to the PID everything is the same but it wont connect at all now. Do you think this is a glitch in the app or is my temp sensor broke and not sending a temp to my ECU. No codes are showing. Is anybody else having this problem.
Edit: Never mind I see what happened when I used torque scan it replace my IAT PID with a different one even though I had entered the correct on in manually before using torque scan.
Old May 29, 2014 | 03:49 PM
  #58
Viperoni's Avatar
Originally Posted by bratboy90
CUSTOM CODES:
IAT2:
OBD2 Mode & PID: 222006
Long Name: Intake Air Temp 2
Short Name: IAT2
Min value: 0.0
Maximum Value: 200.0
Scale: x1
Unit Type: C
Equation: A-40
OBD Header: Auto
I need to give it some more time, but I really quickly tried this but my readout is continually in the 70c (150f) range, anybody else get that problem?
NM, I found out that my IC pump isn't working and the units were celcius, not farenheit.
Old Jun 6, 2014 | 07:26 PM
  #59
08VRSS's Avatar
Is there a pid to read the charge pipe map sensor to get accurate boost readings above 22.5psi ?
Old Jun 7, 2014 | 12:09 PM
  #60
sLAsh's Avatar
Not sure if this helps you because I have a lsj and don't have to worry about boosting over 22.5
In settings/obd2 adapter settings/boost calculation method it let's you choose maf, map or an alternate method
Old Jun 8, 2014 | 04:33 PM
  #61
08VRSS's Avatar
Nah it's very inaccurate, I need to find the pid for the lower charge pipe map sensor bc it's not limited to boost reading over 22.5 like the manifold sensor is, even though they are both 3 bar sensors. Even tried torque scan and after 4 hours of scanning errored and excited.......
Old Sep 9, 2014 | 04:08 PM
  #62
thebr0ken's Avatar
So I setup the info according to OP and was getting too low of a value so I assumed that it was in Celsius. Intake was at 73.4 şF, IAT2 showed 53 şF which seemed low. I switched units for everything to Celsius and Intake was 24 şC and IAT2 was at 12.8 şC. WTH, I do have a secondary cooler and am using a combination dex-cool/water wetter, but there is absolutely no way that it can be 80 şF outside and my IAT2 is 53 şF. I wasn't getting on it, but can it really be 20 şF below intake temp????
Old Sep 11, 2014 | 03:30 PM
  #63
harperrwh's Avatar
Anyone know the pid for Afr
Anyone know pid for afr
Old Sep 12, 2014 | 06:58 PM
  #64
thebr0ken's Avatar
Mine seems to work with:
pid: 22119e
min: 0
max: 255
scale: x1
unit: :1
Equation: A/10
ODB Header Auto
that was one of the default settings when I added the gm predefined set.
Old Feb 6, 2015 | 02:21 PM
  #65
hawkssoccer11's Avatar
just bought the app and have the Bluetooth device to run this now one of my questions is does this use internet data because ill be using my phone for this?
Old Feb 6, 2015 | 02:37 PM
  #66
Olybaltss's Avatar
the connection is via bluetooth, so i wouldn't think there is too much data connectivity unless you're sending logs or using it for GPS functionality, but i could be wrong. Use it for a few days, and then check in your "mobile data" section of settings, you can see exactly how much data that app uses and get an idea of if you're safe or not.
Old Feb 6, 2015 | 02:53 PM
  #67
yeah true ill use it on my home tonight and see what if it does or not.
Old Dec 3, 2015 | 10:48 PM
  #68
matthewj182's Avatar
Pretty sweet app!
I changed the theme to match more with the OEM gauges. Using it on my Note 4 for now and might use an old Galaxy S3 for a permanent option. The IAT2 seem kinda low, i'll have to double check the settings.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
TedSS
26
Oct 10, 2015 04:30 PM
Builttss
Oct 4, 2015 10:21 AM
