06 SS Antenna help
Old Aug 13, 2013 | 12:23 PM
blueLNFftw's Avatar
06 SS Antenna help
The antenna bracket on my car broke. What do I need to replace it, part numbers? I cant tell how the base was even attached to the bracket. Also, is the piece that the antenna screws onto called "antenna ground plate"?
Old Aug 14, 2013 | 04:25 AM
EmperorJJ1's Avatar
idk but it sounds right the antenna piece is called antenna ground plate:
https://www.cobaltss.net/gallery/fil...5/105_0735.jpg
Old Aug 15, 2013 | 04:09 PM
ROB517's Avatar
sounds worse than it really is but I just zip tied it to the bracket and so far so good. I put a shorty on also.
Old Aug 15, 2013 | 04:36 PM
blueLNFftw's Avatar
It seems like the original owner put loctite on the shaft or something because his antenna got stolen before. I crushed the base metal with vice grips and still cant get the mast off.
Old Aug 15, 2013 | 04:41 PM
andrewcarr1993's Avatar
I ended up having to use vice grips too and it's now held on by a zip tie.
Old Aug 15, 2013 | 05:16 PM
ROB517's Avatar
no it's rusted on... i had the same problem
chefhhr
Oct 26, 2015 10:36 PM
dieGone
Sep 23, 2015 10:20 AM
truray4
How to Guide
Feb 27, 2008 09:51 PM
Iroc
How to Guide
Feb 9, 2006 11:54 PM
