3 prong rocker switch w/ LED question????
i got this 3 prong rocker LED switch and its diagram says weird **** lol....
this is what it says on the back of the switch...
im guessing earth means ground
load means power in and
supply means power out???
help pls
help pls
ok my friend just broke it down for me .....
earth is ground
load goes to what you are trying to power (neons, leds, fogs or w/e)
supply is coming from the battery or relay to power everything
earth is ground
lol ah ok local i was about to say damn stalker how do u know what the hell he is using the switch for... want the JJ secret for low power switches???
put the switch there by the cig lighter and just tap there for power /ground. The cig lighter fuse is 15A and unless ur crazy with what u plug into them u will be fine just make sure to put a fuse inline even thou the wire is short
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Iceberg
Sep 29, 2015 12:33 PM
