The ACC Switch
Old Jun 27, 2006 | 05:19 PM
xspyder85x's Avatar
The ACC Switch
When i ran the wire to the sunroof panel, there was nothing there so i dicided to run it to the wiper blade switch. is there any long term problem for this?
Old Jun 27, 2006 | 11:47 PM
tiny's Avatar
shouldnt be a problem, your system will work whenever your wipers will work
edit: not literally, but physically when you can turn your wipers on and off, the system will be on
the system will play regardless of whether you have your wipers on
Old Jun 28, 2006 | 12:27 AM
xspyder85x's Avatar
yea it works good, is there anyway to set the radio to work with the feature that turns the power off when i open the door, you know when i turn the car off the radio still plays untill i open the door?
Old Jul 4, 2006 | 07:51 PM
xtremeGM's Avatar
Thats part of the RAP Retained Accesory Power. The only way you will get that is by taping into something that has power. I believe the windows fall under the RAP functions. But its not something you can just set a headunit to do.
Old Jul 5, 2006 | 01:55 AM
xspyder85x's Avatar
hmm i am going to have to look into changing that
Old Jul 5, 2006 | 08:21 AM
fljohnboy's Avatar
What are you wiring in anyway? On my other car with sunroof I wired my radar detector into the sunroof switch with no problem and it would stay on like the radio and turn off when door opened. On my Cobalt now with no sunroof I wired my xm into the sunroof fuse in the fuse panel. You need to use a test light on the wires on sunroof switch when the key is turned on
Old Jul 5, 2006 | 01:32 PM
xspyder85x's Avatar
ok thanks
Sl0wbaltSS
Nov 21, 2018 11:11 PM
ricklovin93
Aug 27, 2016 06:35 PM
Cobalt08LS
Jun 19, 2016 07:29 PM
dieGone
Sep 23, 2015 10:20 AM
TylerJHowell
Sep 21, 2015 06:47 PM
