adding a battery?
Old Mar 31, 2008 | 12:04 PM
britt's Avatar
adding a battery?
okay, so if i wanted to add another battery to my balt so i dont run my stock one down how would i do that?
i mean doesnt the stock battery "recharge" so to speak, so if you add another one, how would it recharge?
p.s. i know that i can just get a yellowtop but im just going through all of the possibilities.
Old Mar 31, 2008 | 02:00 PM
James Rayth's Avatar
Use this calculator http://www.kinetikaudio.com/calc.asp
You'll need terminals for your old and new batteries and a relay to go between them. You run a remote wire from the ignition to the relay. When the car is off, the relay doesn't allow the extra battery to pull a charge. When it is on, it lets the battery charge. That way it doesn't run down your starter battery.
Old Mar 31, 2008 | 02:05 PM
raptors_67's Avatar
Look for a battery isolator if you're going to do this they usually arent over 20 bucks. It's hard to just find a relay that is going to be able to handle that much current.
Old Mar 31, 2008 | 02:33 PM
britt's Avatar
do you guys think that if i just get a yellow top that it wont run down with a 300 watt 4chanel amp and a 1000watt 2 channel for two 12s?
Old Mar 31, 2008 | 02:36 PM
mkulrey13's Avatar
My stock battery doesnt run down with my 10" L7 and ZX750.1 amp going full blast for 15 mins...you must be punching out insane power or something.
Old Mar 31, 2008 | 03:01 PM
britt's Avatar
yah but thats just one amp.
i only have a 300 watt 4 channel right now, but im getting a 1000 watt for two 12's later down the road. and i was just wondering if i needed to replace or get a new battery.
Old Mar 31, 2008 | 03:48 PM
aj_92rs's Avatar
A battery isolator is what you want. Get one and you'll still be able to start your car even after the one for the stereo system goes dead.
Plus it makes your alternator's job a little easier. Without an isolator, one battery will constantly drain the other until peak voltage is equal between the two. That rarely happens.
Old Mar 31, 2008 | 06:21 PM
I think you should get a Kinetic 1400 (or similar) and a high current relay, like the Stinger SR200 (~$50). That way you will never touch your starting battery and the relay keeps the second battery from touching your starter battery when the car is off.
Old Apr 3, 2008 | 05:37 AM
raptors_67's Avatar
britt if that's all you are looking at using power wise a single yellow top or if you can afford it a kinetic will be plenty. There's really no need to waste money trying to put another battery in. Good deep cycle and you should be fine.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
grampss
Sep 27, 2015 08:51 PM
c_m_shooter
Sep 27, 2015 04:40 PM
