Adding extra speakers
Old Mar 8, 2012 | 10:35 PM
08baltls's Avatar
Well that's kind of difficult to tell where specifically that's at so on my car I figure some where like here:
In that black area under the insert somewhere.
Old Mar 9, 2012 | 01:23 AM
EmperorJJ1's Avatar
oh my bad reading> me... sorry my pic in the back like rear seats whoops
Old Mar 9, 2012 | 02:05 AM
08baltls's Avatar
Oh. Haha. Nah my son sits back there and he would screw up the speakers if they were right beside him.
I've also got another question. I'm looking for subs and I'm having a hard time deciding on a setup.
Would one 12" sub like a kicker comp 12 be enough? I don't want so much bass that the whole car rattles to death but just some added thump. So would a single 12 be good or do I need to go with two? Also what kind of wattage should I look for in an amp?
Old Mar 9, 2012 | 02:10 AM
EmperorJJ1's Avatar
ya the kicker comp isnt a huge speaker so u should be ok. personally id say do a CVR 10 instead it will cost a little more but has more potential and better sound. that way u can start it sorta low and still have more left in the sub if u wanted
Old Mar 16, 2012 | 01:44 AM
08baltls's Avatar
Ok so I've been reading and thinking and reading some more.
Honestly, I'm not real sure about the sub simply because it would be right behind my 6 year old son. I highly doubt he's going to like that too much.
Now the h/u I have is only pushing 22w per speaker. I'm sure it's an improvement over factory, but it still seems low.
I know I'm probably going to add the extra door speakers and wire them in parallel. I know a lot of people do this to drop the impedance to get more output. I'm not really sure if it will work too well off the headunit itself but it's what I'm going to do.
Also I may look into a low watt 4 channel amp to power them a little better. The only problem is that my h/u only has one set of RCA outs. Most of the 4 channel amps I have seen require two RCA in cables, one for each bank. So if I go that route I'm going to have to get line output converters. The only thing I'm worried about with this is running speaker wires such a long distance. Would they need to be shielded better since they are going to be running such a distance? Cause the amp will be mounted in the trunk. Or would it be safe to mount an amp under one of the front seats?
Old Mar 16, 2012 | 01:48 AM
EmperorJJ1's Avatar
u have the pioneer stock system or no?
Old Mar 16, 2012 | 01:55 AM
08baltls's Avatar
No, aftermarket Pioneer.
Old Mar 16, 2012 | 02:11 AM
EmperorJJ1's Avatar
ok if i were u i would go with a 2 channel for the fronts and leave the rears on the HU. save u money as far as amp goes and meh might as well... if u insist on 4 channel look at one that utilizes high level input and use high level for all 4 channels. i would also install the amp first then go about adding an extra pair of speakers if u see fit
heres an idea of what behind the door panel looks like
Old Mar 18, 2012 | 02:09 PM
kingmanbc's Avatar
Old Mar 18, 2012 | 08:11 PM
EmperorJJ1's Avatar
um wouldnt it make more sense to turn the amp around?
Old Mar 19, 2012 | 07:20 PM
  #36
kingmanbc's Avatar
Its easy to tune plus when someone looks in the back it doesn't look backwards... and no its not finished yet lol
Old Mar 19, 2012 | 07:45 PM
  #37
08baltls's Avatar
Why'd you put two amps in the rear deck instead of hiding them? That just screams steal them to me.
Old Mar 19, 2012 | 07:50 PM
  #38
kingmanbc's Avatar
No one can see them I have 20% tint and I have an alarm system
Old Mar 20, 2012 | 01:36 AM
  #39
EmperorJJ1's Avatar
lol id talk **** but i have 5 amps on the rear deck so 2 seems pretty reasonable in comparison
i agree with teh tunign part but sorry wires would look much better the other way
Old Mar 20, 2012 | 12:34 PM
  #40
kingmanbc's Avatar
Do you have a pic of 5 amps on your deck
Old Mar 20, 2012 | 01:44 PM
  #41
EmperorJJ1's Avatar
no i do not
Old Mar 20, 2012 | 03:12 PM
  #42
08baltls's Avatar
Well I popped today and bought a sub, amp, box, and wiring. I still am not too sure if I want an amp an sub setup so I wasn't going to spend a lot of money on one. My brother was getting rid of his setup out of his focus since he's about to get rid of the car. So for $40 I got his whole setup. It's only a cheap DUAL amp and sub but for the price I figured it was a good start to decide if I really wanted that kind of sub and if I decide that I do I won't loose money when upgrading. It was kind of a win win for me.
I'll post up some pics when I get it installed. I'm also going to use this as a wy of deciding if I want to add the two more door speakers.
Old Mar 20, 2012 | 03:44 PM
  #43
kingmanbc's Avatar
Or you could always put pods on your kick panel, thats what I did. Easyer than cutting into the door panel.
Old Mar 20, 2012 | 09:37 PM
  #44
08baltls's Avatar
Ok so here's the pictures. Yes it's cheap Walmart ****. But it actually sounds pretty good minus the rattles that I knew would come with adding any kind of sub and amp.
Forgive the bad quality pics and both seats not being down, I'm using my cell phone and didn't want to move my sons booster seat.
It's only a 400 watt amp but it actually hits pretty hard. Plenty hard enough for me.
Old Mar 21, 2012 | 01:27 AM
  #45
EmperorJJ1's Avatar
try turning the box around to face the back
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
Oct 20, 2015 09:56 PM
TurboWood
Sep 28, 2015 05:10 AM
