Aeroforce Wideband
Ok,
So I got my Aeroforce Wideband kit to hook up to my Interceptor.
The install today didnt go as well as I had hoped.
I found a place in my fuse box, hooked a wire up, but its kinda ghetto
hook up. I cant find a main wire for when the key is in Run.
So I put the cover back on and it squishes the wires. So im going to have to drill
a hole in the cover, and run the wirse in that way.
Getting them through my firewall wasnt fun either.
But I managed, now the lil plug with the stock wires is kinda goofed to the side.
Im worried about the wires chaffing against stuff.
So anyway, I coudlnt get my car high enough with jackstands to sawp out my O2 sensor.
I dont even know if my new sensor will fit in the same hole or if ill need to use the bung.
Anyways, Next week when I change my oil, ill take it to where I can use a lift and such.
Well I have my wire for the O2 sensor temporarrly ziptied to my strut tower bar until I can get that routed proprerly and installed on my O2 sensor....
Question though...
Im comming through the firewall at the location where
the How To guid for installing a wideband shows...
I plan on placeing my amp device thing in the lil box
by the left knee, since I never use it for anything ealse.
But I cant see how to routh the wirse up there. Right now
I just shoved them under the carpet. But its between the
brake and the clutch. How can i get the wirse arround the pedals
into the lil box without them interfearing with my pedals?
Question though...
Sl0wbaltSS
Nov 21, 2018 11:11 PM
n20saturn
Sep 30, 2015 12:26 AM
