Aftermarket HU + LS?
I'm looking at the Pioneer FH-P8000BT for my first mod to my car. Basic electrical knowledge here, so I think I'm fine on that aspect. What should I use to maintain door chimes and other stock creature comforts?
I've got a 2007 Cobalt LS with just the four speaker package... one day I'll add a sub to the mix and an amp.
For something under $500, is there anything decent in a 10" - 12" sub and amp?
Thanks!
Thanks!
i just installed one of those HUs.
IIRC, the only way to maintain the chimes is with the GM harness kit that's like $100
Last edited by joeworkstoohard; Jul 18, 2008 at 09:59 PM. Reason: Automerged Doublepost
i used the pac gm 11 bit harness and although it remains the door chimes, the turn signals are nearly silent, but i need my chimes, i always sit in the car a dn listen to music or change and listen to music and forget my keys
cobalt has not alot of space, im going to put in two kicker comp vt 12" subs (go for about 140 a piece on ebay) and an alpine amp
sub and amp for unde 500? shoot kicker makes a singel L5 loaded box prob be plenty for alittle nice bump in the cobalt. i have two l5's and a 1000 watt kicker mono and its plenty. its for sale accualy but, shipping would kick you in the ace for two subs a box and amp.
What harness did you use? Where did you hook up to ignition power, did you have to use a relay? (The guy in the shop said I had to... weird.)
sorry but **** those chimes
their so annoying.
i might just go get an aftermarket HU because the chimes are SOOO annoying. i always sit in my car listen to music with the door open and hold my foot on the little door button to make it STFU.
their so annoying.
You should just do it yourself, the harness there talking about (your local shop) won't retain the chimes if you have to tap a power source
Heres the parts you need and prices (in $ Canadian, from ebay)
Pioneer FH-P8000BT-$279.99
GMOS LAN 03-$109.99
Merta 95-3302 -$9.99
Metra 40 CR10-$9.99 (ant adapter)
This will retain the chimes, and make it so you don't have to tap a power source. Your local shop wants to use a cheaper adapter ($20.00) that means there charging you close to $200 for the install
GMOS LAN 03-$109.99
Thanks Spun! Perfect! I'll just save up for this stuff (gotta repair my bumper first
) and then it's all good to go! The shop wanted $100 to install it, and they were overstocked in the HU's so they were going to give it to me $100 off. I dunno how he calculated $512. I'm doing it myself anyway.
You talking about the GMOS LAN? (lol)
Look for an ebay store called Audio Savings
Everything I quoted I found there
http://stores.ebay.com/AUDIOSAVINGS-...3aFQ3aSTQQtZkm
Thanks for your help
I'm considering loosing my door chimes. It's a pain in the ass when I want my music on and my driver side door open. The music either has to be louder than the chimes, or the door has to be closed. I'm leaning towards the $20 harness. :P
Do you have the make/model of the harness you have?
