Amp question
Old Mar 27, 2008 | 11:49 AM
UmeNNis's Avatar
Amp question
Alright, when it comes to car audio I really don't know what I'm doing... I'm installing an amp and sub woofer, is there anything that needs to go between the amp and the power source from the battery or can it just be directly connected?
Old Mar 27, 2008 | 11:55 AM
Firebirdhorn's Avatar
a good size fuse should be spliced in there. 100 amp was the last size i used in my formula.
Old Mar 27, 2008 | 12:23 PM
UmeNNis's Avatar
Well I already have multiple fuses in my amp... is that good enough, or no?
Old Mar 27, 2008 | 12:25 PM
they should always come with fuses in the amp, atleast thats what I have always used. But you still need an in-line fuse from the power supply to the amp, even if it has a couple of 30 A fuses on the side of the amp already.
Old Mar 27, 2008 | 12:26 PM
UmeNNis's Avatar
Okay but other than that I don't need anything?
Old Mar 27, 2008 | 12:30 PM
just the RCA's that'll either hook up to an aftermarket stereo, or an inverter so you can hook it up to the factory stereo, the remote wire, and the ground wire. Ground wire should be of the same gauge as the power wire. other than that you should be good to go!
2FST4U's Avatar
First off what kinda Watts are you pushing outta that amp. That depends on the size of the fuse you wanna have between the amp and battery. Ex. I have 2400 watts and I have a Stinger 250 fuse with Ot gauge wireing. so say you have about an 800 watt amp you wanna have about 6 or 8 gauge wire with about a 100 - 150 amp fuse
Old Mar 27, 2008 | 12:33 PM
UmeNNis's Avatar
well its a 1500 w multichannel, but I will only be using the 300w class D sub output on it for now, does that matter? what guage power wire you think i need?
BLAZIN07SS's Avatar
I'm too JDM for you
you should always try to at least match the fuses output on the amp. ex: if amp has two 30amp fuses, use at least a 60amp in-line fuse.
btw, do you have an aftermarket head unit?
Old Mar 27, 2008 | 12:42 PM
UmeNNis's Avatar
alright gotcha on the fuses. and negative - stock hu.
edit - why do you ask about the hu
Old Mar 27, 2008 | 01:54 PM
TeDy's Avatar
Don't want to start anything... But I've always used the fuse size for how much the wire can handle.
Like a 4 gauge can handle 120 amps, so I'll probably put like an 100 amp fuse or something.
Old Mar 27, 2008 | 05:21 PM
UmeNNis's Avatar
Hey guys one more quick question... I got it all wired up, but now I need to connect a lead to the 'remote turn on lead of the head unit' but I am using the stock head unit... does it even have one? lol... and if it does, how the hell do I find it?
If I have to, I'll just be lazy and put in a manual switch lol
Old Mar 27, 2008 | 06:33 PM
Spun's Avatar
I believe its the pink wire,
Check the sticky on pinouts, its in there somewhere
Old Mar 27, 2008 | 07:52 PM
BLAZIN07SS's Avatar
I'm too JDM for you
1) buy a mini add a fuse and an extra mini fuse
2) pull out sunroof or wiper fuse from passenger side panel on center console
3) place mini add a fuse in either the sunroof or wiper fuse socket with the 2 fuses
4) crimp remote wire on the end of mini add a fuse
5) and your done
Old Mar 27, 2008 | 07:57 PM
kenstacy125's Avatar
all i did was run a wire up to my fuse box found the radio fuse and put the wire in one the the fuse prong holes and then put the fuse back in so anytime the radio is on the amp is on ( i.e. when you turn the car off and take out the key and the radio is still on till you open the door, so you can still bump till you open the door)
Old Mar 28, 2008 | 02:59 AM
EmperorJJ1's Avatar
same with the sunroof and wiper fuses. Only difference is your radio pulls more power then the wipers and usually peeps dont have sunroofs. So it makes sense to use them so you dont overload the radio fuse
Old Mar 28, 2008 | 11:43 AM
2FST4U's Avatar
I tapped my remote into the tail lights
brandon04
Oct 21, 2015 07:04 AM
Iceberg
Sep 29, 2015 12:33 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
c_m_shooter
Sep 27, 2015 04:40 PM
