Amp to rear battery
Old May 15, 2005 | 12:03 AM
PatDamanCobalt's Avatar
Amp to rear battery
Can you run power wire from the battery in the trunk to your amp instead of running it through the firewall in the front?
Old May 15, 2005 | 05:18 PM
wbrault's Avatar
yes, that is where i ran my power wire
Old May 16, 2005 | 03:31 PM
tiny's Avatar
of course, what would you hook it up to in the front of the car???!
and i used the factory ground mounting bracket that the negative terminal attaches too, also
Old May 16, 2005 | 03:45 PM
Chevy4Life85's Avatar
Yes where would you run it to up front? Your battery is in the trunk, there arent two
Old May 17, 2005 | 09:41 AM
Nightcrawler's Avatar
But there are terminals in the front. So, you COULD hook it up there, but I have no idea why you'd want to.
Old Jul 18, 2005 | 12:39 AM
ike0824's Avatar
Well regardless where you decide to hook the amp up to, just make sure your fuse is within 6 inches of the battery(trunk) or at the positive terminal(up front).
I have a feeling some people might forget since the battery is in the trunk(we all know some people are easily confused)
ike
Sl0wbaltSS
Nov 21, 2018 11:11 PM
DANRICKARD
Oct 1, 2015 12:08 AM
Delta coupe
Sep 30, 2015 08:11 AM
grampss
Sep 27, 2015 08:51 PM
c_m_shooter
Sep 27, 2015 04:40 PM
