Amp to rear battery
Originally Posted by PatDamanCobalt
Can you run power wire from the battery in the trunk to your amp instead of running it through the firewall in the front?
of course, what would you hook it up to in the front of the car???!
and i used the factory ground mounting bracket that the negative terminal attaches too, also
Yes where would you run it to up front? Your battery is in the trunk, there arent two
Well regardless where you decide to hook the amp up to, just make sure your fuse is within 6 inches of the battery(trunk) or at the positive terminal(up front).
I have a feeling some people might forget since the battery is in the trunk(we all know some people are easily confused)
ike
ike
Sl0wbaltSS
Nov 21, 2018 11:11 PM
DANRICKARD
Oct 1, 2015 12:08 AM
Delta coupe
Sep 30, 2015 08:11 AM
