amp straight to battery in trunk??
Old Jan 11, 2006 | 04:08 PM
Lorenzo's Avatar
im going to install a 12" sub ill prolly head up to best buy and see wha tthey have...i already have a 1000 watt kenwood amp...its very nice i used it to ran my 2 15" in my blazer those ****** bumped lol....anyways can i just hook it up to the battery in the trunk?? ive already replaced the deck and all of the speakers in the car so all thats left is a sub and the amp....i just realized the battery was in the trunk i didnt even know that **** lol.....im assuming it shouldnt be a problem because thats what ive always done in my cars....anyways just wondering thanks....
Old Jan 11, 2006 | 04:18 PM
NJBLUESS's Avatar
Not a problem. Saves on cost of wire and less voltage drop to the amp. Not to forget ease of installation.
Old Jan 11, 2006 | 04:52 PM
azreal's Avatar
having the battery in the trunk is such a luxury
Old Jan 11, 2006 | 04:55 PM
hardtocope's Avatar
does anyone know exactly how to bolt the power wire to the postive terminal.. i'm kinda of having trouble and i notice there is a stud that sticks out in the postive terminal but has no nut. maybe if i figured out the size of that nut i could place the power wire on that.
Old Jan 11, 2006 | 05:12 PM
co-yellow-balt's Avatar
yes use like a battery terminal connector
kinda like this
http://www.absak.com/catalog/product...roducts_id/530
cut off some to clear just for the wires and put in the slot and crimp it so it wont come un-done and then for protection wrap it up with some electrical tape to make sure it wont come undone (back up).
but yes definately run it back to your battery, instead of using feets of power wire your only going to use inches. actually i used 2 feet, so i could move it around. good luck man and if u got any more questions lay them on me.
Old Jan 11, 2006 | 05:15 PM
hardtocope's Avatar
doesn't that device u mentioned above replace the whole battery terminal?
Old Jan 11, 2006 | 05:37 PM
no u slide it onto the bolt.
Old Jan 11, 2006 | 06:57 PM
hardtocope's Avatar
can u get a picture of how it hooks up?
Old Jan 11, 2006 | 07:47 PM
Bandit2941's Avatar
I just used the stud and put a nut and lock washer on it after soldering a ring terminal onto my 4ga wire. I routed the wire right out under the factory red clip cover thing and it looks stock. I forget what size the nut is now but it's metric, any hardware store should have what you need.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
DANRICKARD
Oct 1, 2015 12:08 AM
Tupp
Sep 30, 2015 08:18 PM
grampss
Sep 27, 2015 08:51 PM
c_m_shooter
Sep 27, 2015 04:40 PM
