Another 10" Question but for a LS
Old Aug 11, 2008 | 12:03 AM
UgliestTurtle's Avatar
I have a new 08" LS. I was wondering if it is possible to put the 10 in. pioneer subwoofer into a stock LS. If not how can i with out going aftermarket?
Old Aug 11, 2008 | 12:47 AM
CoolNate32's Avatar
I'm not sure if it would be easy to add the factory one, or worth it. I would recommend getting a good 10" or 12" sub with a decent amp. Will still be affordable, and have that stock look inside the car.
Old Aug 11, 2008 | 12:44 PM
EmperorJJ1's Avatar
you would need an aftermarket amp to power the sub but it is possible to put it in
Old Aug 11, 2008 | 12:50 PM
bryce712's Avatar
^^^ listen to him hes good with audio
Old Aug 11, 2008 | 07:42 PM
BMC2U's Avatar
I put the SS Pioneer 10" sub and enclosure in my 08 LS. The holes are there in the interior trunk panel, but you will need to come up with your own mounting hardware which isn't hard to do. I am powering mine off of a separate amplifier
Old Aug 11, 2008 | 10:26 PM
EmperorJJ1's Avatar
yup thats the way to do it
Old Aug 13, 2008 | 09:08 PM
evowake's Avatar
is it absolutely necessary to have a separate amp to run it? you can't just splice with a LLO from one of the rears?
Old Aug 14, 2008 | 01:00 AM
EmperorJJ1's Avatar
^^^ what?
Old Aug 14, 2008 | 09:51 AM
evowake's Avatar
can you just splice a line level out from one of the rear deck speakers and run it to the factory sub if you want to run it on a base stereo? or do you NEED to use an external amp?
Old Aug 14, 2008 | 09:16 PM
yobos4vr's Avatar
the amp provides the power for the sub. the line level out is needed for the signal but there no power for the subwoofer. so in short no amp no sub.
Old Aug 14, 2008 | 09:22 PM
68nova200's Avatar
i think there is a how to for this.
Old Aug 14, 2008 | 09:30 PM
blu3_v1p3r's Avatar
no you cant just slipce into unless you get a converter. I have the stock deck with 2 subs and my amp running from it.... I bought a converter that coverts the LLO to the RCA plugs that plug into the anp. The converter cost around $20. You also need to connect the remote wire from the converter to the amp.
Also while having the stock look is nice, if your going for a lot of base your not going to like that sub. If you can find a good shallow sub that will fit in there you might be better off but at that point you might as well just go with a regular sub inclosure...
Old Aug 14, 2008 | 09:33 PM
silver187666's Avatar
ugliest i got a good amp and speakers for sale
https://www.cobaltss.net/forums/stuff-137/closet-clean-out-127796/
Old Aug 14, 2008 | 09:36 PM
joeworkstoohard's Avatar
https://www.cobaltss.net/forums/show...&highlight=box
Old Aug 14, 2008 | 11:43 PM
EmperorJJ1's Avatar
mida im all confused now adays...
OK scratch all the above info in this thread. Yes you can replace the stock sub with an aftermarket one BUT depending on the coil configuration and or ohms of the sub you probably will get LESS power from the stock amp. Aftermarket subs are usually more sensitive so would be louder then stock BUT even if you had the same power it wouldn't be terribly noticeable (at least not to warrant a $200 sub) So to answer your question yes you can replace only the stock sub with an aftermarket one of your choice but its best to add an amp for more power as well
brandon04
Oct 21, 2015 07:04 AM
patooyee
Oct 15, 2015 05:11 PM
Iceberg
Sep 29, 2015 12:33 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
