Any one have happy wit there stock Hu wit aftermarket subs??
wow, what are you saying? if your asking how to hook up aftermarket subs to the stock headunit, then you just get an inline output converter. tap into the rear speakers and then hook up your amp like normal.
I have an aftermarket D class amp hooked up through that same converter but through the stock sub and it hits nice. Only problem is that like all GM headunits, when you raise the volume the bass drops off a bit to save the stock speakers from blowing. Still sounds nice with a Massive D class 1,000.1 Amp and Two 10" Fosgates. And it's setup so that when I decide to go to the track I can take the box out and plug the stock sub back in and it will work fine.
