any of you bypass factory amp How?
Old Mar 26, 2008 | 10:47 AM
xtrmsnd's Avatar
has any of you guys bypassed the factory amp? how do you do it . or how did you get in the door jam to run your speaker wires back to your aftermarket amp. is there a harness to bypass amp?
Old Mar 26, 2008 | 10:49 AM
Drakonen2000's Avatar
tap into your rear deck speakers....there is a how-to on the site somehwere for this
Old Mar 26, 2008 | 01:01 PM
Spun's Avatar
Are you talking about amping up yor front speakers with an aftermarket amp or are you trying to run an aftermarket amp with speaker level inputs?
As for wiring through the molex in the door...I dont have the actual link right now but go to www.the12volt.com theres a how to with good detail on how to wire through a door.
Old Mar 26, 2008 | 10:00 PM
SS SCHGD's Avatar
THis what your looking to do?
was a pain to drill out the plug, but worked out well. I ran 2 lines into the door, one 12 guage and one 16 guage for my tweets.
I am running a Rockford Fosgate 360.1 off the stock head unit to a 5 channel amp in the trunk, all my wires run to the trunk. (you could just as easily run a line output Converter from the rear speakers to the amp)
Old Mar 27, 2008 | 04:46 AM
EmperorJJ1's Avatar
yup depends on why u are bypassing it to what it requires. also how u are running speakers
Old Mar 27, 2008 | 05:00 AM
rmorris003's Avatar
looks interesting, im going to be putting jbl power series comps on an aftermarket amp and this looks helpful
Old Mar 27, 2008 | 10:44 AM
xtrmsnd's Avatar
I'v always ran it through the factory wire harness apparantly going through the factory amp sounded great . I think the amp is giving me a ground loop because i get a horrible shreeking noise coming out of my speakers when i turn it on . its not the convention low altanator wine its liek a banshee is stuck in my speakers. I assummed i would just individualaly wire each speaker to my aftermarket amp. I have all powerbass 3XL series components and 6x9's they sound incredible. oh yeah one other thing when i just turn on the acc of the car and dont start my car its deafening how loud the shreek is. low voltage ? thanks in advance
Old Mar 28, 2008 | 09:55 PM
SS SCHGD's Avatar
I was going to do the same thing I did in the red car in my other one (before I sold it) for JBL GTI equipment, but use 2 runs of 10 Awg speaker wire and had plenty of room. I'll add a couple more pics to see where the wires ended up.
the wires run to the underside of the rear deck (right behind the seats) to the crossovers (I have the same 6.5" Diamond D6 components at each corner) and then to the Amp mounted on Plexi under the rear deck.
turbochargedss2012
Sep 20, 2023 12:17 PM
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
importkiller
Sep 30, 2015 07:18 PM
cw383
Sep 30, 2015 12:41 AM
c_m_shooter
Sep 27, 2015 04:40 PM
