Anyone who installed pioneer nave/dvd unit
Old Feb 6, 2010 | 01:20 PM
chood711's Avatar
I bought the pioneer avic-x910bt and want to get a few things straight before starting install.
1. I already have 2 items(interceptor and wideband gauges) hooked to the sunroof fuse. would it hurt to wire the HU up to it?
2. I have done alot of searching. Is the VSS wire the yellow wire on the bottom harness in the ecm?
3. To bypass the the parking break, I need to hook the parking break wire to a toggle switch and ground the switch?
I appreciate any help
Old Feb 6, 2010 | 01:37 PM
TommyP's Avatar
AWD > FWD
I just bought one as well. Hopefully it will be here by next weekend so I can install it. If you get it in before I do, let me know how the install goes, and how much you like it. To answer one of your questions, #3 specifically, when I hooked up my old pioneer dvd player, that's exactly what I did to bypass the safety feature, so I would imagine that will work here too.
Old Feb 7, 2010 | 01:16 AM
EmperorJJ1's Avatar
#1 if u dont have a sunroof then ur fine if you do... thats pushing it but the pioneer gets most of its power from constant and the acc is for the most part just a remote turn on of sorts
#2 **** idk man
#3 yes
Old Feb 7, 2010 | 01:40 AM
SlowBalt_06's Avatar
1. your fine there...
2..i'd like to know i just bougt the eclipse 6620
3.. you can ground it to anything really ..i just grounded it to a random bolt.....
Old Feb 7, 2010 | 02:07 AM
exiged's Avatar
why would you even want to do that? just install it the way its ment to be. . .
Old Feb 7, 2010 | 02:18 AM
EmperorJJ1's Avatar
pioneer and eclipse arent the same thou man
Old Feb 7, 2010 | 03:33 PM
chood711's Avatar
even do what? if your talking about the bypass..the reason would be that if a passenger wanted to watch a dvd or if i wanted to put an address in for the navi i could without have to pull up the e-brake.
Old Feb 7, 2010 | 03:35 PM
true but we did the same to my buddys d3
Old Feb 7, 2010 | 07:15 PM
exiged's Avatar
i was referring to getting power from the sunroof fue.
Old Feb 8, 2010 | 12:51 AM
chood711's Avatar
its not getting full power from the fuse it is basically using it as a remote wire so that it only gets power when the key is turned to acc or the car is running.
i installed it today..but i cant get no sound from speakers... i have an 06 ss and used the 70-2103 harness. i searched and found that i needed to use the pink wire in the harness as the amp turn on..i dont know if that was for a 06 though. any help appreciated.
Old Feb 8, 2010 | 12:55 AM
EmperorJJ1's Avatar
correct... there should be a blue/white wire in the 2103 harness u need to connect to amp turn on. If not its the pink one in the car
Old Feb 8, 2010 | 12:56 AM
SS33's Avatar
Search my threads for my install, I have alot of pics from when I put in my Avic D-2
1) Don't do that, it's lazy and sketchy. Buy a fuse tap and use one of your spare fuse slots. Clean, easy, and reliable. Pics for ref. in my install thread
2) Not 100% sure. I got lazy on this part and never went back and found a good VSS lead. My GPS works flawlessly without it hooked up
3) Not certain on your model. check Avic411.com LOADS of great info to be found on that site. My D2 just required 1 jumper wire on the harness and it works perfect. I watch DVD's (external player) and have full access to all navi and other functions while driving
Old Feb 10, 2010 | 12:39 AM
chood711's Avatar
i got the thing in and running smooth as of today...I will say that I like it from what I got to mess with it.. the bypass is a little different but not hard at all. It's currentley not on a switch but that may change. ill post pics tomorrow.
Old Feb 10, 2010 | 12:46 AM
get it ground without using a toggle
Old Feb 10, 2010 | 12:55 AM
chood711's Avatar
i got it bypassed but im thinking it may be best if on a switch in case i get pulled over or what not.
Old Feb 10, 2010 | 08:40 AM
SS33's Avatar
Nah, if you get pulled over just switch to map view, you're golden
Old Feb 10, 2010 | 09:07 AM
iboost's Avatar
true or hit SRC and change it to the radio thats what I do...I have mine wired up through a relay. How's the whole "just grounding" the parking brake wire working? I've heard multiple things about doing it. Some people say it works, some say it doesn't. I'm bout to install a new head unit in my girls VW and if I can just ground the wire on a p3100 head unit I would MUCH rather do that then wire up a relay...
Old Feb 10, 2010 | 09:20 AM
like they said, switch over to radio or to map.
Old Feb 13, 2010 | 06:15 AM
johnsteveen's Avatar
Just i like to heard radio instead of map watching. Whenever i moving alone for a long distance, almost i
prefer to heard radio on different channels.. In my old car i hadn't dual player, it was only supported radio
function.
Old Feb 13, 2010 | 10:15 AM
iboost's Avatar
when I drive to Ny from Ky and I have my ipod in, I can really only listen to it for like maybe...3 hours. Then I just get bored of music in general...I'll put in a movie and I don't even have to watch it...just listening to it was much better than music when you are just crusing...I don't put on movies I've never seen by the way...that way I'm not tempted to watch them.
Old Feb 14, 2010 | 12:58 AM
EmperorJJ1's Avatar
lol really hinelli... how many songs do u have?
Old Feb 14, 2010 | 11:50 AM
hell with music i have the music videos burned lol
Old Feb 15, 2010 | 10:02 PM
SS33's Avatar
function.
I think I might have no clue what you're saying there, but you can play music, video, whatever audio source you want while the map is displayed.
Jan 12, 2016 12:01 AM
agentirons
Oct 16, 2015 02:11 AM
justinchinn
Oct 2, 2015 12:18 PM
nathan112i
Sep 30, 2015 07:12 PM
Sep 27, 2015 08:53 PM
