Audio Issue. Please Help.
Old May 3, 2008 | 02:21 PM
XStorm43's Avatar
Hey guys, I just put my 2 12's and my amp in my car this morning and I have a problem. My amp seems to not be communicating with my subs to give them the juice. The amp powers on fine and everything can be programmed through the after market H/U. I have no idea what the problem is and would appreciate any input anyone has to offer. Thanks in advance.
Old May 3, 2008 | 03:40 PM
EmperorJJ1's Avatar
need a it more specific explanation. are ur rcas good?
Old May 3, 2008 | 03:43 PM
Spun's Avatar
Did you try opening the box to make sure there is wire running to the sub?
HidKidSS's Avatar
i had that problem if its the same one i had in the back of your head unit you should have 1 output plug that says subs...you will need a female(i think thats the right1) to turn that 1 output plus into 2 so you can run the rca wire to the back of the headunit
heres the link of the adaptor that youll need if thats your problem
http://www.google.com/products/catal...59590439091863
Old May 3, 2008 | 04:02 PM
XStorm43's Avatar
Well guys I had this whole system hooked up and working great last summer and I re-installed the same way I did before. RCAs are brand new. I just opened the new pack this morning. I'm baffled. I have no idea what the problem is. Speaker wires are good, no positive/negatives are crossed.. IDK.. Thanks for your time guys, if you need any more info let me know.
My H/U does not have Mono, it has the 2 input ports for left/right. Thanks!
Brand new!
Old May 3, 2008 | 04:23 PM
highrider43's Avatar
Maybe check your sub-out setting on the headunit......it might default to "off" when the unit has no power or when you reset the headunit after install...
Old May 3, 2008 | 04:45 PM
XStorm43's Avatar
No, that's good to go....
Old May 4, 2008 | 04:13 AM
EmperorJJ1's Avatar
best thing to do is get a multimeter and check stuff out. lots of possible problems
turbochargedss2012
Sep 20, 2023 12:17 PM
Tupp
Sep 30, 2015 08:18 PM
Sep 30, 2015 07:22 AM
SlowSaturn
Sep 28, 2015 11:03 AM
Turbo6
Sep 24, 2015 04:15 PM
