audio question
Old May 24, 2008 | 09:19 PM
josh22's Avatar
audio question
Hows it going? quick stupid question. i have a pioneer avic n2 and i just ran all the wires and hooked up an amp and sub. the amp is getting power but i have nothing coming out of the subs, i checked all wires and they are connected properly. Do i have to unconnect my factory sub even though its not on any of my av ports?
thanks
Old May 25, 2008 | 12:41 AM
EmperorJJ1's Avatar
test for ACV on the rca to make sure they are live... test ohms at the end of the speaker wire on the amp side to make sure the subs connected correctly. test ACV on the amp terminals to make sure ur getting output
Old May 25, 2008 | 10:20 AM
josh22's Avatar
ok i got them working, but they are not hitting as hard as they should, ill have to play around with the hu settings and see what i can come up with.
Old May 26, 2008 | 01:30 PM
josh22's Avatar
ok still not working properly not sure what to do next, so i guess ill stop by a local audio shop and see whats gong on.
Old May 26, 2008 | 07:59 PM
EmperorJJ1's Avatar
did u adjust your gains accordingly on the amps? avic only puts out 2v and i bet ur used to a 5v deck
Old May 26, 2008 | 09:16 PM
Spun's Avatar
Check and make sure your + and - speaker wires are correct (polarity) if you have them reversed (even check inside the box) the subs will still play but they will seem like there only giving a fraction of the output they should be.
What amp and sub do you have?
How are you running it (4ohm, 2ohm, bridged, stereo)
What do you have the gain set at?
What is the x-over set at?
Old May 26, 2008 | 09:23 PM
josh22's Avatar
ill check the gains first thing tomorrow, i had the system set up in my wifes cavy and it was great, all i did was pull it out and put it in? thanks for all the info hopefully i get this thing figured out.
Old May 26, 2008 | 10:04 PM
Spun's Avatar
Only thing different is the headunit?
Check to make sure you have the RCA's running off the right output.
Someone else had an issue like this. I think he had to unhook the RCA's from the sub out and move them to the rear out, I think it had something to do with only having 1 set of RCA's running off the back of the deck, I'll try to find the thread.
In any case Good Luck
brandon04
Oct 21, 2015 07:04 AM
patooyee
Oct 15, 2015 05:11 PM
Iceberg
Sep 29, 2015 12:33 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
