battery keeps falling over in trunk
Old Sep 10, 2009 | 06:47 PM
brickloaf's Avatar
alright so i have 2 yellow tops in my trunk (above carpet)
there is one on each side and there sitting in the spot where the stock sub is on teh SS's
the driver side one stays up just fine, but the passanger side one ALWAYS falls over now, pretty much everytime i drive i can hear that bitch tip over, i have a ton of velcro on the bottom of both the batteries, but it still tips over, ive tried putting stuff under the battery so it leans the oppisite side so it wont fall, but guess what...it still falls over
anyone have any ideas on what i can do? i have no idea since my drivers side battery is fine but pass. one is fucked...
heres a pic of the battery that falls over....the amp inst in the trunk right now, but when i put it back in i dont want my battery falling all over it.
Old Sep 10, 2009 | 06:52 PM
northvibe's Avatar
um...secure it the proper way? bolt that bitch down.
Old Sep 10, 2009 | 07:02 PM
mrsilent13's Avatar
make a bracket and bolt it to the side of the car or the floor of the trunk either or...that should fix your problem
Old Sep 10, 2009 | 07:44 PM
arkkornkid's Avatar
If you really want to stay with the velcro thing: it's taller than it is deep = top heavy, so just slap some velcro on the side and lay it down. It'll try to slide vs. tip over. Optima's are dry-cell batteries so you can mount them in any position you want.
Old Sep 10, 2009 | 07:54 PM
brickloaf's Avatar
my wiring is set up for that position, and im willing to bet id have to **** around with it a bunch to get it perfect again. also, it would look real werid IMO to have batteries laying on the side. and to the other posts, i would bolt it down but the only thing under it is the carpet, the the chassis metal and id rather not drill in to my car anymore.
Old Sep 10, 2009 | 08:25 PM
northvibe's Avatar
then you fail at installing...
why not also Velcro the side to the "wall" of the trunk liner.
Old Sep 10, 2009 | 08:37 PM
all4glh's Avatar
If you rewired it so that the wires came from the side, you could use the wires themselves to hold the battery upright.
Old Sep 10, 2009 | 08:42 PM
tuner923's Avatar
duct tape!!!!
or box them in and cover it with carpet
Old Sep 10, 2009 | 10:20 PM
brickloaf's Avatar
thats a good idea but these batteries are heavy as **** and a piece of velco is no match for it
not really sure what you mean? what side are you talking about
Old Sep 10, 2009 | 10:21 PM
northvibe's Avatar
....then you answered your own question. Like stated before why not reroute the cable and turn them on their side since they are a dry battery. Then the velcro could work, I think. The other thing is in a crash those batteries are going to go flying if velcro'd down. For safety concerns Id do a bolt/strap setup.
pimpnwink's Avatar
2x4 some nails and duct tape will make sure your batteries never move even in a rollover.
Old Sep 10, 2009 | 10:25 PM
cli3e0339384398jk's Avatar
bolting down is going to be your best option even though you dont want to.
Old Sep 10, 2009 | 10:40 PM
brickloaf's Avatar
does anyone know whats under where my battery is sitting, last time i drilled a hole i hit my fuel line and had to pay 300+ for tow/repairs
Old Sep 11, 2009 | 12:53 AM
EmperorJJ1's Avatar
there isnt much of anything. look under the car like i said the first time ... bu i also sprayed great foam in the back because it dips down... another one of the 4 or so reasons its falling over
Old Sep 11, 2009 | 12:55 AM
madmark's Avatar
get a strap on
Old Sep 11, 2009 | 03:37 PM
LTBALTBMX's Avatar
Gorilla tape
Old Sep 13, 2009 | 06:22 PM
brickloaf's Avatar
looked under the car and couldnt really tell if there was anything under my batt...really want to drill it now since it falls over basically everytime I drive
Old Sep 17, 2009 | 12:53 AM
Routs's Avatar
Originally Posted by madmark
get a strap on
He should really ask his girl if she's cool with that first...
Old Sep 17, 2009 | 01:22 AM
EmperorJJ1's Avatar
lol thats classic
Old Sep 17, 2009 | 11:53 AM
Iancredible's Avatar
yes sir
I got a brilliant idea ... go to a shop and pay someone to do it. You are very lucky that the battery hasn't toppled over and hit your amp shorting out the system
Your ghetto ass velcro trip and doing nothing but wasting your time and money
Old Sep 17, 2009 | 01:52 PM
jon_k's Avatar
If you're concerned about looks then fabricate a bracket and have it chromed.
If you want the easiest solution, side mount it for better stability.
Your only options are to either bolt it or make it more stable. Otherwise, get comfortable with it sliding around, but it's a matter of time until it shorts somewhere.
Old Sep 17, 2009 | 01:58 PM
rnjmur's Avatar
X2
What happens if you get in a wreck and that battery becomes a cannonball? You think that back seat has any chance of stopping that battery from flying into the passenger compartment?
Old Sep 17, 2009 | 02:19 PM
jon_k's Avatar
Originally Posted by rnjmur
X2
I'd hope his sub box is large enough to block projectiles. I'd be more concerned of shorts and battery damage by a rolling battery.
Old Sep 17, 2009 | 04:09 PM
brickloaf's Avatar
Originally Posted by Iancredible
yes sir
are you ******* retarded? why would i need someone to hook up a ******* battery, its positive and negative...i have ghetto ass velcro on the other side and guess what, NEVER has it slid around, same with my sub box....
anyways, i found this little metal piece that i can partially slide under the battery and it has this thing that sticks up and keeps it from falling over, and you cant even see it
id be more concerned with my 500 dollar sub being used to block like a 50-60 lb battery
WhineSSbaby
Sep 1, 2020 12:39 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
grampss
Sep 27, 2015 08:51 PM
c_m_shooter
Sep 27, 2015 04:40 PM
CobaltSS 16
Sep 6, 2015 02:04 PM
