Battery question/opinion
Old Mar 5, 2012 | 09:42 PM
vypr's Avatar
Hi,
I have 2 kinetik batteries in my cobalt. I have a HC1200 in the stock location in the trunk and an HC1800 wired in parallel. They are a couple years old and it seems they might be losing their kick, I was thinkin of a single battery solution and puttin it up where my hc1800 is. Maybe because they are different capacitys? A single battery solution like a HC2400 or a D3100, I can put it up where the HC1800 is in my trunk. I'm not running that much power maybe 2KRMS T20001bd wired to 2 ohms and a t600-4 in stereo. DO you think that one battery is better than having 2? I know it would be simpler for me just to have one. Opions please
Thanks
Old Mar 6, 2012 | 03:37 AM
EmperorJJ1's Avatar
one battery is techniclly better then 2 but really if the 2 are the same size its not that big of a diff since urs are different sizes thou thats why u may be getting issues
Old Mar 6, 2012 | 06:47 AM
vypr's Avatar
Thanks for the reply. So I think I am going to get just one d3100 and replace the t20001bd with a kicker zx2500.1 and remove my 10 farad hybrid cap which I really dont think is making any difference.
Thanks
Old Mar 6, 2012 | 11:44 PM
EmperorJJ1's Avatar
what kind of cap is it?
Old Mar 7, 2012 | 01:01 AM
vypr's Avatar
Fosgate 10farad hybrid
Old Mar 7, 2012 | 01:09 AM
CannonBalt's Avatar
ditch the Cap & Do the big 3 upgrade:
How to upgrade the Big Three
Old Mar 7, 2012 | 01:16 AM
EmperorJJ1's Avatar
big 3 doesnt do to much for us. upping the batt ground is really the only thing worth the money in copper wire
ill take the cap thou if u dont want it.. lol jk but id do the batt upgrade first then see what voltage is at it might not be helping much but who knows
Old Mar 7, 2012 | 01:27 AM
CannonBalt's Avatar
So if you drop hard bass on a stock system you wouldnt see voltage drop?
Old Mar 7, 2012 | 02:01 AM
EmperorJJ1's Avatar
not sure the stock system can "drop hard bass" but with the battery in the truck alt to battery and alt chassis upgrades dont do much... not saying its not worth doing for some of the bigger systems but its not like a honda night and day difference
battery ground upgrade is a must thou
Old Mar 7, 2012 | 02:05 AM
Dontstoprunning's Avatar
I'm running a optima bluetop, marine use
Old Mar 7, 2012 | 02:06 AM
CannonBalt's Avatar
No no, i meant like a kicker 2500.1 on a stock electrical system haha
Old Mar 7, 2012 | 02:10 AM
EmperorJJ1's Avatar
right of course u will and upping the batt ground is a must then battery then alt and then alt to batt/alt ground wire.
u can do them in any order but that's the most effective. trust me i ran 2 1/0 grounds from my batteries to the front alt
Old Mar 7, 2012 | 07:08 AM
vypr's Avatar
Thank you for your responses. I have a d3100 coming today. Ditching the cap, Ditching the 2 kinetiks for the d3100. I have already upgraded my electrical a while ago. I have a 250 amp DC power alt, 1/0 from alt to batteries in the trunk, 1/0 from engine block to chassis, and 1/0 ground wire. even running that t20001bd at 2 ohms at full tilt I can drop the voltage with the engine running down to 11 volts. Should I ground the subwoofer amp and the battery seperatley? I had some whine in my highs but I seprately grounded my t600-4 and it helped alot. I was going to go over my electrical tonight, I had a few things in mind, Clean the chassis to ground 1/0 connection, I looked at it last night and I can see some corrosion, I guess from the road salt and such. Resolder a new connector on the 1/0 cable connected to the alt. One thing that I might consider is upgrade the wire from the alt to the fusebox it is still the stock wire. Is that wire worth upgrading? Also I was going to attach another ground wire to one of the mouting bolts on the alternator and also connect that to the chassis. From the voltage drop I am getting I have some resistance somewhere.
Thanks
Old Mar 7, 2012 | 09:51 AM
EmperorJJ1's Avatar
right well id see what happens after the new batt is put in and u redo those corroded connectors then go from there
Old Mar 7, 2012 | 11:05 AM
vypr's Avatar
Okay JJ I will let you know how it goes
Thanks
Old Mar 13, 2012 | 09:16 AM
vypr's Avatar
The D3100 solved my voltage problems. Headlights only dim when I really push the amp, but then they only dim slightly. I still have the work to do with the connectors under the hood. I will probally do that this weekend. I have not checked my voltage drop but I could imagine it is far less than before. I probally gained a db with the new battery.
Old Mar 13, 2012 | 02:10 PM
EmperorJJ1's Avatar
yup not surprised with 2 missed matched size batts they go pretty quick with a big ass amp
any pics of it installed?
Old Mar 14, 2012 | 06:49 AM
vypr's Avatar
I will try to post some this weekend. I have been so busy at work. I have it by the left rear wheel well. There is nothing holding it down but the weight of it seems to keep it in place. I dont know how I would even secure it in place. but if it really doesnt move im not going to worry about it
WhineSSbaby
Sep 1, 2020 12:39 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
grampss
Sep 27, 2015 08:51 PM
c_m_shooter
Sep 27, 2015 04:40 PM
Gugi96
Sep 15, 2015 12:24 AM
