best grounding post
Old Feb 27, 2006 | 03:14 PM
hardtocope's Avatar
best grounding post
there is to brackets right behind the seats under the carpet. the brackets have huge bolts in them, they look like a good spot to ground my amp on. Has anyone else tried this spot for grounding yet?
Also do all amps have protection mode? I just bought this alpine amp and it doesn't say anywhere in the manual that it has protection mode.
Old Feb 27, 2006 | 03:16 PM
R33P3R007's Avatar
360 L337 User
I know what your talking about.. Looks like it would work. Can't you just ground it in the trunk near or with the battery
Old Feb 27, 2006 | 03:23 PM
hardtocope's Avatar
well i would rather have my amp have its own grounding post. plus the amp is mounted near my seat so that would be the closes grounding point. but i'm not sure what that bracket is being used for? if it's connected to the gas tank is that safe to ground to?
Old Feb 27, 2006 | 04:48 PM
Shermen's Avatar
just use the bolt for the back seat. i mean if your gonna mount the amp on the back seat. it would require the shortest amount of wire.
Old Feb 27, 2006 | 04:52 PM
hardtocope's Avatar
wheres the bolt for the back seat?
Old Feb 27, 2006 | 05:03 PM
Shermen's Avatar
if you pull out the trunk mat, (climing in through the back seat) their are 2 bolts with mounts, (the mounts are black) either of the bolts will work. they are both grounded. if that doesnt help i can get pictures up tomorrow. and look on the net to see if your amp has a protection on it. most amps do but then again.
edit:: the spot you have in your original post is what i am talking about
Old Feb 27, 2006 | 05:05 PM
hardtocope's Avatar
theres one bolt on one side of the trunk and another bolt on the other side of the trunk holding a black bracket in place... is that the one ur talking about?
Old Feb 27, 2006 | 06:26 PM
hardtocope's Avatar
are you sure the bolts in the black brackets are for the rear seats?
Old Feb 27, 2006 | 06:46 PM
tsmock's Avatar
I always used the seatbelt bolt under the rear seat on my Cavaliers. I haven't taken the back apart on my cobalt yet though...
Old Feb 28, 2006 | 09:46 AM
hardtocope's Avatar
can you take a picture of what ur talking about?
Old Apr 20, 2006 | 08:12 AM
slowhand1972's Avatar
Truck bolts
I would advise against using those bolts. That's where mine are now and there is not a very good ground connection there. My sub levels increase and decrease with my shifting using that bolt. In fact I found this thread by looking for a better place in my trunk to ground.
Old Apr 20, 2006 | 10:01 AM
ExHondaMan's Avatar
Domestics Pwn
I have my amps grounded there right now (after moving them from another point in the trunk).... Since I moved them to the rear seat bolts i've picked up some engine noise in my speakers.. I need to get off my ass and relocate them to somewhere else.
Old Apr 20, 2006 | 09:37 PM
tiny's Avatar
ground it to the spot where the battery is grounded to
i mean physically where the negative for the battery comes from, ground it there as well
its gonna be the best ground in the car, obviously
Old Apr 23, 2006 | 11:13 AM
BigAl's Avatar
I have mine grounded where Tiny said, on the battery ground. Your sure it'll work fine there.
Old May 4, 2006 | 02:36 AM
DruZ24's Avatar
i used the antenna bolt and have had no issues what so ever and it is close so little wiring
Old May 4, 2006 | 02:55 AM
importkiller's Avatar
i also am using the battery ground, it works fine!
Oct 20, 2015 09:56 PM
dennis69
Oct 20, 2015 07:39 AM
riceburner
Oct 2, 2015 05:47 PM
ThoR294
Sep 28, 2015 05:31 PM
