best grounds
Old Mar 24, 2007 | 10:59 AM
musifreak190's Avatar
best grounds
where would be the best place to wire an amps ground into..their are two bolts wen you pull up the carpet next to the seats in the trunk...or the negative terminal on the battery..or the ground to the chassis that the negative of the battery is wires too?
Old Mar 24, 2007 | 11:08 AM
SilverSS/SC's Avatar
That would the best ground imo.
Old Mar 24, 2007 | 03:22 PM
tricky1's Avatar
X2 thats the one I use.
Old Mar 24, 2007 | 07:58 PM
yellow2003xtreme's Avatar
I also used the same ground as the above posters.
Old Mar 24, 2007 | 09:33 PM
Xavipheus's Avatar
Am I the only one who cant disconnect that bolt the negative wire for the battery is connected under? Like I try to unbolt it and the entire metal thing bends. Anyways i drilled a hole in the trunk left of the wheel well
ricklovin93
Aug 27, 2016 06:35 PM
Oct 20, 2015 09:56 PM
satisfied
Oct 19, 2015 12:35 AM
InfraRedline
Drag Racing
35
Sep 29, 2015 02:09 PM
SStevie
Sep 21, 2015 11:37 AM
