best low end sub
best low end sub
hey guys,looking to replace my factory pioneer sub in my 09 with a good low end sub adding a separate amp to drive it,prob 300watt.Current sub is dual 2 ohm voice coil,can I go with a staright 4 ohm,etc?Thanks
your going to need to use a shallow sub if your wanting to use the stock box, as long as ur using an aftermarket amp you can get whatever impedance sub to match the amp, if ur going to use the stock amp you cant bridge it or in any way connect the 2 channels so DVC 2 ohm would be the best option in that case
importkiller
Sep 30, 2015 07:18 PM
