to big of an amp?
Old Sep 13, 2008 | 07:01 PM
brickloaf's Avatar
to big of an amp?
I just got 2 boston g5 subs (450rms each) and a t10001bd rockford amp, which does 1000rms at 1 ohm, i was wondering if having a amp that puts out more power than the subs can handle is a bad thing?
any help appericated
Old Sep 13, 2008 | 07:08 PM
joeworkstoohard's Avatar
thjat's a matter of debate. really, you have to remember, that subs draw power, the amp doesn't force it.
now, going way way way over the rated power isn't a good thing,
also, IIRC, the g5 is a single 4 ohm coil, what does this amp supply at 2 ohm? or 4?
Old Sep 13, 2008 | 07:11 PM
brickloaf's Avatar
mine has dual 4 ohm voice coils, not single
its 750rms at 2ohm
1000 at 1ohm
Old Sep 13, 2008 | 07:15 PM
http://akamaipix.crutchfield.com/ca/...4-ohm_mono.jpg
do it in 4 ohm
Old Sep 13, 2008 | 07:19 PM
brickloaf's Avatar
i wont be installing it myself, cause i would forsure mess it up, but i just needed to know about overpowering
thanks though
Old Sep 14, 2008 | 02:56 AM
creedin's Avatar
no do not do it in four ohm, take the amp back and get a 4ohm amp that is about 900 - 1100 watts rms at 4 ohms then wire in four ohms
Old Sep 14, 2008 | 07:33 AM
EmperorJJ1's Avatar
wire it at 1 ohm... just dont be stupid g5s will handle the power but those amps are around ~1.5-2k at 14.4
Old Sep 15, 2008 | 12:13 AM
brickloaf's Avatar
no idea what your talking about
idk how to wire it at 1 ohm, but i wont be installing it myself so i guess i should just tell them to wire it to 1ohm?
and i have no idea what 14.4 means
thanks though
Old Sep 15, 2008 | 01:13 AM
EmperorJJ1's Avatar
any competent installer would wire it at 1 ohm. 14.4 is voltage.
Just keep the gain a bit lower and don't go crazy on the bass boost (we normally dont use it but if u have a knob then just have really low gain and you'll be fine)
i really wouldnt worry so much because they should be able to tune it correctly. But just in case when your playing it loud check to see how much the subs are moving. if it looks too much then turn it down
Old Sep 15, 2008 | 11:55 PM
brickloaf's Avatar
06MetallicBalt
Jul 20, 2025 08:47 PM
bigdeertz
Nov 17, 2016 09:41 AM
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
c_m_shooter
Sep 27, 2015 04:40 PM
