Bought a Subwoofer need help
Old Dec 9, 2008 | 06:17 PM
  #51
Jplaya023's Avatar
its a 10mm deep socket attachment. and like cblt12 said u need a pretty long extension on it to get into the holes.
Old Dec 9, 2008 | 06:18 PM
  #52
ikeryder13's Avatar
anyone heard of a crunch amp???
Old Dec 9, 2008 | 06:36 PM
  #53
Jplaya023's Avatar
absolutely not lol....amps arnt too expensive and you definitely do not want to go cheap on an amp. anything with a cooling system is essential. ive had my speaker amp shut down in the summer and all i heard was bass. made me so nervous but i just had to let it cool and it came back on. both of my amps are clarion and the subwoofer amp has lasted me over 5 years. its a very nicely built amp and they are very reasonably priced...especially a two channel
Old Dec 9, 2008 | 08:05 PM
  #54
ikeryder13's Avatar
so should i do a mono amp or run a bridge setup
Old Dec 9, 2008 | 09:13 PM
  #55
cereal83's Avatar
I would go mono
Old Dec 9, 2008 | 11:05 PM
  #56
Jplaya023's Avatar
mono is ok but i think bridged is more efficient. its cheaper and you're running at full power at all times.
Old Dec 10, 2008 | 02:28 AM
  #57
RooTBeeR's Avatar
i can take out your stock sub for you when i do your mounts
Old Dec 10, 2008 | 03:15 AM
  #58
EmperorJJ1's Avatar
Originally Posted by ikeryder13
stock head unit
its real simple but can be fucked up at the same time.
Since the stock sub is a dual coil you want to tap those for the LOC. you want to make sure to use t-taps a few inches from the plug and dont cut it.
this gives you the signal for the amp and allows you to still connect or disconnect the sub at your leasure. Just have them screw the amp to the back seat. Then when you need weight savings for the track all you have to pull out is the aftermarket sub and box and tape the wires so they dont touch (or pull the remote and tape it) and plug the stock sub back in. I wouldn't use both simultaneously but if the install is done like stated above it should only take a few minutes to go from one to the other. Just be careful with that plug so you dont break it if you do this often.
crunch is the cheaper version of hifonics. which is a cheap imitation amp to begin with
depends on the amp really. I would put a rockford fosgate to the test against any amp out there and i bet it would take longer to thermal. and most of them dont have fans... and the ones that do it you would be hard pressed to know when its on without removing the cover.
Last edited by EmperorJJ1; Dec 10, 2008 at 03:15 AM. Reason: Automerged Doublepost
Old Dec 10, 2008 | 05:36 AM
  #59
ikeryder13's Avatar
emperor come install my stuff lol
Old Dec 10, 2008 | 01:38 PM
  #60
Jplaya023's Avatar
i have a clarion 400W two channel amp for my subs and i can hear the fan as soon as i start my car (with the seats down and my head right near it of course). I havent had that thing shut down on me once...works like a champ
Old Dec 10, 2008 | 03:00 PM
  #61
ikeryder13's Avatar
i have another question... the sub is in a vented box... does it matter which way the sub faces? like should it be facing out the trunk or facing towards the driver?
will my battery be ok?
ah yes motor mounts!
Last edited by ikeryder13; Dec 10, 2008 at 03:00 PM. Reason: Automerged Doublepost
Old Dec 10, 2008 | 03:17 PM
  #62
Jplaya023's Avatar
your battery will be fine as long as you don't run the stereo when the car is off...you can run it when the car is off but be prepared for your battery to die in less than 10 minutes
Old Dec 10, 2008 | 04:17 PM
  #63
ikeryder13's Avatar
will it last longer with a mono?
bump?
Last edited by ikeryder13; Dec 10, 2008 at 04:17 PM. Reason: Automerged Doublepost
Old Dec 10, 2008 | 04:19 PM
  #64
FASTECOTEC's Avatar
get a RF mono sub amp i have used lots of them and they pound hard
Old Dec 10, 2008 | 04:39 PM
  #65
Jplaya023's Avatar
nah...any amp is going to drain your battery pretty hard with the car off...you could upgrade to an optima yellow battery but ive heard of some fitment issues....not too sure tho
Old Dec 10, 2008 | 04:40 PM
  #66
ikeryder13's Avatar
i see...
Old Dec 10, 2008 | 09:26 PM
  #67
RooTBeeR's Avatar
i have an 800 watt mono pioneer amp and i ran it with the car off for a good 5 hours or so and it was still running the radio strong...but it didnt have enough power for to start the car lol, put it on the charger for a lil and it fired right up again been fine ever since.
bump?
if your worried about killing the batt just get a capacitor, i'v been thinking about getting one.
Old Dec 10, 2008 | 09:28 PM
  #68
Tank07's Avatar
i just did my system..........u need a single mono amp get one rated for 600 RMS.........that way u can expand ur system
i doubt u need a capicator im running a 360 rms 4 channel amp and a 600 watt mono amp without one
i also used a 12 inch bazooka tube.........that thing hits fing hard........and if i need room in the trunk to use it i unstrap and unhook it and im done :-)
Old Dec 10, 2008 | 09:32 PM
  #69
07cobalt4life's Avatar
i like my 750watt sony amp that i got
Old Dec 10, 2008 | 09:35 PM
  #70
Jplaya023's Avatar
well i hate to contradict but a capacitor does not do what you think it does. The capacitor stores power when you aren't using a lot and shoots the power back when your system is withdrawing more power than your car can supply. For example if your headlights dim and your interior light dim when the subs are hitting then it is overdrawing power. The capacitor however does not "store" power. Its not like a battery. so if you ran a capacitor when the engine is off it will only suck more power from the battery for when it is needed by the amps. Don't be mistaken. Most cars do not need a capacitor and it does nothing for your battery life.
You can run the system off of your battery when the car is off for quite some time but just don't expect to start your car afterward. The only thing that would increase the life of your battery would be to upgrade to a new battery such as a deep cell optima yellow. I just heard from my local audio store that there were some fitment issues but he could be wrong
Old Dec 10, 2008 | 09:54 PM
  #71
RooTBeeR's Avatar
i only suggest a capacitor if you are planning on running your system with out the engine running for long periods of time. with a sub and/or amp that small you wont need one as long as the car is running
thank you sir, you learn something new every day...i honestly had no real idea that what a capacitor did, just a guess from the little ive heard.
Old Dec 10, 2008 | 10:59 PM
  #72
EmperorJJ1's Avatar
a class D mono is normally more efficent then a clas AB 2 channel but with that lil amount of poweryou probably wouldnt notice. I wouldnt recommend running the system with the car off regardless of what you have. Any amp will drain your battery the main question is how long before your stranded because you cant start your car. Even i dont do it and i have 3 batteries and the ones for the sub amp are isolated so they can drain all day and it wouldnt effect starting my car.
A cap is negative once your car is off. Running they do help on the smaller systems but normally a upgraded battery helps more regardless. A cap only works with the car on until then its just hurting you
ikey i would if you were local but thats not the case
anything i missed?
Old Dec 10, 2008 | 11:36 PM
  #73
RooTBeeR's Avatar
I omnly did it when i was working on my car in my driveway lol, i know better than to strand myself haha
Eric, I can install that for you too lol if you dont want a shop to do it...i did my own sub and amp, "basic" stereo equipment is relatively easy to install
Old Dec 10, 2008 | 11:40 PM
  #74
EmperorJJ1's Avatar
lol i know but the ikey seemed a lil confused and i just wanted to make 100% sure. Ive done it too prior to having the 2 batteries set up. Car was parked for 2 weeks working on the second alt and i would jam out every once in a while. Funny thing was the batt charger broke so i couldnt charge it up (belt was off so i couldnt crank it either. Sat almost fully drained for a week or so before i charged it with a charger
Old Dec 10, 2008 | 11:45 PM
  #75
RooTBeeR's Avatar
lol, ouch...so what stereo do you have in there if you need to have 2 alts and 2 batts?
