bypass parking brake wire
Old 04-28-2008, 08:24 PM
ibyoyo's Avatar
Exclamation bypass parking brake wire
im sure there have been many post about this got a new pioneer radio with DVD they say to hook up the parking brake wire to 2 positive side of ur parking brake if i just hook it up 2 a 12 volt constant is this the same thing???
Old 04-28-2008, 08:25 PM
beercan's Avatar
Ground it thats all you have to do
Old 04-28-2008, 08:31 PM
ibyoyo's Avatar
then y does it say to hook it up to the positive side???
Old 04-28-2008, 08:32 PM
beercan's Avatar
every dvd head unit i have ever installed has had to be grounded. What pioneer is it?
Old 04-28-2008, 08:33 PM
ibyoyo's Avatar
avh-p5000dvd
Old 04-29-2008, 08:18 AM
EmperorJJ1's Avatar
pioneers are smart... u need either a switch or a bypass module. Grounding it out wont work
ur lucky u didnt get a navi unit otherwise u would be fucked
Old 04-29-2008, 08:21 AM
BOOSSTED 06's Avatar
HAHAHA, um no
I have the avic d3 which has the same harness as the unit your installing. On the white harnbess that plugs into the back of your unit take the mute wire and move it to the pin hole that is emty above or below where it currently is, its the yellow wire with the black stripe. Then after you move that wire, ground that mute wire, and the parking brake wire and your bypass is done
pioneer has put in that mute wire feature but its not hard at all to do
Old 04-29-2008, 08:59 PM
ibyoyo's Avatar
why cant u just ground the mute and parking brake wires together without moving the wire????
Old 04-29-2008, 09:03 PM
skidizzle105's Avatar
okay i have the d3 and i have a by-pass switch that was installed and once i start moving it shuts off, i would assume its from the navi in it
Old 04-29-2008, 09:25 PM
ibyoyo's Avatar
my pioneer doesnt have nav in it also ne1 have problems using the gmos lan 04 harness?? hooked up all my wires then my rca's for my front and rear outputs but cant get sound??? crutchfield said the harness is bad neideas??????????
Old 04-29-2008, 09:29 PM
c0baltic's Avatar
yea .. i have an alpine and people think that buy just grounding it it will work .. some units like mine only go into dvd mode when the break in pressed then the hand break is put on and only in that order so i have a bypas module a pac-7 and it will send a signal to 2 wires 1 sec apart to simulate the break pedal then handbreak being set
Old 04-29-2008, 09:47 PM
i know you dont have nav, but the bypass is done the same way on the pioneers with video, nav whatever. My bypass works no matter when, no switch needed, move the mute wire and ground the mute and the parking brake wires and your bypass is set, its a pioneer thing, why you move the pin I dont know but I know it wont work if you leave the mute in the original spot
Old 04-30-2008, 12:24 AM
EmperorJJ1's Avatar
look on the stock harness for a pink wire. See if that is connected on the other side to anything. It should be remote
Old 04-30-2008, 08:08 AM
rrutter81's Avatar
eclipse avn 6610 works if you just ground the wire. It is a pretty sweet double din unit although the back bracket needs to be removed for it to fit.
turbochargedss2012
09-20-2023 12:17 PM
06MetallicBalt
08-17-2021 03:40 PM
biniecki
10-25-2015 02:23 PM
Quick Reply: bypass parking brake wire
