Car Wont Start After Mod Instal! HELP!
Old Mar 17, 2014 | 06:14 PM
Blue-SS/SC-Cobalt's Avatar
Unhappy Car Wont Start After Mod Instal! HELP!
So i purchased a power antenna for my 06 cobalt ss/sc i took the old antenna off and plugged in the power antenna i did not hook up the power wires to the radio for it to go up and down just plugged in coax for radio antenna power. So i go to start car and a security lock out comes on when i turn it over it will make a buzzing noise but will not start fuel pump runs and everything normal just buzzes with security light and won't start. I did have the cd player with a cd playing while installing but nothing got messed up with the CD Player that all works but Radio antenna reception does not work at all. I check all fuses and nothing is blown what is the deal? i don't want to take to dealer for something i can fix myself! Please HELP!
Old Mar 17, 2014 | 06:40 PM
CobaltSS 16's Avatar
damn man, use at least some punctuation... i dunno wtf you're talking about
Old Mar 17, 2014 | 07:47 PM
Yeah never the best in english. I put a power antenna in my car today, only unplugging the coax cable from the stock antenna to hook it up to the power antenna. I hooked up the power antenna to the quarter panel and went to start my car then the security light comes on and all it does is click or buzz when trying to start. So is there a way to re-set the car with a long way like 45min process to fix this so my car will start again? Ive done the disconnect the battery trick already but didn't work for me. -Shortened and used commas that better? haha
Old Mar 17, 2014 | 07:58 PM
cobaltss#01's Avatar
is the antenna still grounded?
Old Mar 17, 2014 | 08:05 PM
The power antenna yes, as for the stock bracket and the holder that you plug the coax into i took that assembly out. The power antenna is not hooked up to the CD player to go up and down only the antenna cable (coax) for the antenna to get a signal.
Thanks a lot for the response I definitely need help with this
Old Mar 17, 2014 | 09:21 PM
BlackielawlessSS's Avatar
You dun fucked up!
Old Mar 17, 2014 | 10:34 PM
sLAsh's Avatar
You listening to CDs while doing the install? Sometimes a low battery will set off the security. Try boosting it or even better put the battery on a charger overnight.
Old Mar 17, 2014 | 10:42 PM
^^ooh thats not a bad idea
this just doesn't seem like something that should keep you from starting your car, OP, lol.
Old Mar 20, 2014 | 02:09 AM
EmperorJJ1's Avatar
if charging the battery doesnt work id yank the batter ground for 10 mins or so and see if that helps any
Old Mar 20, 2014 | 08:38 AM
Any updates?
Old Mar 20, 2014 | 08:49 AM
CSRT4U's Avatar
Why buy a power antenna and not use the power?
Old Mar 20, 2014 | 01:58 PM
Wow it was a bad battery couldn't hold a charge but 60% thanks a lot for the help though really confuses you with the system going crazy when its just a battery.
Reasoning for getting a power antenna without the power is it stays down and doesn't go up i can't stand tall antennas and i would use a shorty but then again i want it down all the way. Still get reception and i don't listen to the radio hardly ever
Once again thanks everyone saved myself money and embarrassment at dealership!
Old Mar 21, 2014 | 10:21 AM
Glad to hear it was just a battery.
Turbo Johnny
Feb 21, 2019 09:41 AM
Decepticon06ss/sc
Oct 16, 2015 09:24 PM
hawkssoccer11
Sep 30, 2015 12:14 PM
ashalle2
Sep 16, 2015 10:36 PM
Getaway_Driver
40
Sep 10, 2015 09:11 AM
