CD player installation help needed
Old Nov 15, 2008 | 01:30 PM
tiny's Avatar
I'm installing a basic Jensen deck in my brother's 2001 V6 Mustang. Amongst a slew of problems blowing dash fuses, the deck will not work. I fixed all the fuses, and got them to work again, but the cd player will not fully power on. It sits in standby, and when you press a button to turn it on, it turns off, and goes into standby. The clock goes back to 12:00, too. I got it to turn on using a fuse wrapped with a wire, but that's when the other fuses blew.
I checked the wires with a testlight beforehand. The 12v aux. power from the factory harness didn't put out voltage, so I set out to hunt for a better input. I do not want to piggy back into the fuse box. I need to find a permanent aux power. Where do I find a good switched 12v source?
Thanks so much, I'm ripping my hair out over this install.
Old Nov 15, 2008 | 03:49 PM
pare_john's Avatar
sounds like instead of having the constant 12v wire hooked to a constant 12v you have it hooked to a switched 12v
Old Nov 15, 2008 | 05:07 PM
Coblasts's Avatar
The wires for the install will all be there in the stock radios connector,why are you looking else where.
Search the internet for the pinout to install it properly.
Better yet get some help rom someone that knows what there doing.
Also never bypass the fuses,I hope you learned your lesson !
Old Nov 15, 2008 | 05:10 PM
originaladrian's Avatar
you tap from the inside fuse box correctly... arrrrgggg everyone does this wrong.
Old Nov 15, 2008 | 09:00 PM
tiny's Avatar
It's plugged from the HU adapter to a factory harness. I connected the wires, yellow to yellow. The wires are both labeled constant 12v. I'm wondering if the harness adapter we got is defective.
The 12v accessory wire does not work. In my post I said that I tested it and it did not put out any voltage. Now I need a new source.
Worst case, I can splice the factory wires before the harness, but I would like to avoid this.
And yes, I did learn my lesson. I hooked it through a fuse to see if the subwoofer/amp installation worked. I blew some fuses, I was an idiot, now I want to get this working and move on.
Old Nov 15, 2008 | 11:09 PM
Switt23's Avatar
A lot of those harnesses are made for the "general" model of a vehicle. Meaning they tested a 98 suburban and a 2004 suburban and both work so 98-04 harness. However it's possible like our radio's the pin-outs changed just slightly.
Old Nov 16, 2008 | 01:18 AM
tiny's Avatar
so I guess I should tap the power and 12v accessory from behind the harness....
Old Nov 16, 2008 | 12:15 PM
EmperorJJ1's Avatar
no if its not after the harness it wont be there before it. pin outs dont really change.
Old Nov 16, 2008 | 02:54 PM
tiny's Avatar
well i'm stumped
i've never had a car that didn't put out the proper voltage from the accessory wire in the harness
Old Nov 16, 2008 | 02:56 PM
Switt23's Avatar
Have you ever wired a suburban? Go hook up a radio to a suburban and tell me they don't change.
Old Nov 16, 2008 | 04:58 PM
EmperorJJ1's Avatar
yes i have wired up a suburbun but i also know gm makes 4 different harnesses that all have the same "plug" so the issue isn't you have to re pin it the issue is you have to get the right one going to walmart doesnt really work
if the acc is fried for whatever reason and its not a fuse i would just re run a new one to the fuse box
Old Nov 17, 2008 | 08:17 AM
Spun's Avatar
2001 Ford
Mustang 2dr Coupe
Radio_memory Grn/yel
Radio_switched Yel/blk
Radio_ground Blk/grn -
Radio_illumination Lt.blu/red
Front_speaker_size 5 X 7'
Front_speaker_location Front Doors
Front_right_speaker_positive Wht/lt.grn
Front_right_speaker_negative Na
Front_left_speaker_positive Org/lt.grn
Front_left_speaker_negative Lt.blu/wht
Rear_speaker_size 5 X 7'
Right_rear_speaker_positive Org/red
Right_rear_speaker_negative Brn/pnk
Rear_left_speaker_positive Gry/lt.blu
Rear_left_speaker_negative Tan/yel
Power_antenna_trigger Amp=blu
Old Nov 18, 2008 | 12:38 AM
tiny's Avatar
Thanks for everyone's help, I figured it out today. I spent hours probing wires with the car on and off. It turned out to be a faulty harness. I thought specifying the make, model, year, engine type, and non-MACH sound system would clue the guys at the store to the right harness. They sold me the wrong one. Once again, thanks for the advice.
Solaris99
28
Mar 15, 2017 01:22 PM
DANRICKARD
Oct 1, 2015 12:08 AM
DocSvensk
Sep 27, 2015 02:24 PM
ChrisTutoki
Sep 24, 2015 08:39 PM
