Cobalt 10" sub
Old Jul 10, 2010 | 12:06 PM
pursuitforever's Avatar
Cobalt 10" sub
I know that you can get the cobalt and it comes with 10" subs in the trunk. mine didnt come with it so i was looking around and i cant seem to find them in the GM cat. Soo i was wondering if u guys knew where i could pick a pair up and also if i need an amp or special wiring for them
Old Jul 10, 2010 | 12:12 PM
donkeyballs's Avatar
You can't get a pair its molded to the left side of the trunk.. Look around for a used one and you need a amp.
Old Jul 10, 2010 | 12:20 PM
scottydoh's Avatar
On a side note, do the non factory equipped cobalts have the necessary mounting holes?
Old Jul 10, 2010 | 12:23 PM
Good question.. Not sure, But i would just buy a after market sound system it would sound a lot better. Unless you need the trunk space
Old Jul 10, 2010 | 12:25 PM
Ya but they can get really expensive especially with the install
Old Jul 10, 2010 | 12:37 PM
it wouldn't take much money to be as loud as the stock 10 it sucks
Old Jul 10, 2010 | 07:22 PM
brickloaf's Avatar
true i could spend like $100 and thump harder than stock
Old Jul 10, 2010 | 11:20 PM
Nighthawk243's Avatar
You can buy them on ebay from LKQ. I did when I had my G5. You will need an aftermarket amp.
Old Jul 11, 2010 | 03:10 AM
EmperorJJ1's Avatar
they have the holes but not the studs and stuff to actually mount it
Old Jul 11, 2010 | 11:29 AM
And what would you do for 100 bucks
Old Jul 11, 2010 | 11:37 AM
chris88z24's Avatar
Make sure you use an aftermarket headunit if you're looking to get the best performance out of it. Preferably one where you can set the rear speakers as sub signal only and adjust/tune accordingly.
My factory Pioneer system bumps SO much harder now that I swapped out the OEM headunit with a Pioneer double din dvd unit.
Superslowbaltt
Sep 22, 2015 10:24 AM
Rayray2781@gmail.com
Sep 20, 2015 01:52 PM
Bluelightning
Sep 8, 2015 05:18 PM
jthwjde
Sep 7, 2015 09:24 AM
