Constant static from one speaker
I have searched and searched and cannot track down what is causing this static. The static only comes from the rear passenger side speaker. Changes with RPM, pops when I push the brake and changes pitch as the interior light dims. I've removed the head unit and looked around countless times and everything looks good but it does go away for a short time when the head unit has been unplugged and plugged back. BTW entire system is stock factory pioneer.
correct. If you were able to slap the unit and it went away then chances are that's what it is. You can try doing a better ground to see if that helps but you may just need to replace it
sinisterSF
Aug 27, 2016 08:33 AM
